Netbook adapter/power supply
Tom
My netbook has gone down, seemingly due to the failure of the power cord. This is a DC 19V Output Current: 1.58A. When initially diagnosing the problem over the last few months, I thought the Jack was wearing out. When I measured the voltage output it was 6.5. When I measured it just post failure, it was around 2 volts. So I am guessing the transformer has been dying over time, rather than the jack failing, or possibly both.
Am I right in thinking the low voltage power supply was trickle charging the battery, so the fact the voltage was falling didn't mater, given the power output was reasonably low.
I have other transformers around the house, and getting a replacement will probably take me about a month, or cost twice what it should. I was wondering whether I could use one of these other transformers, wired for the netbook, in the meantime. They have the same voltage but supply a higher current. Is that a problem? will the device draw only what it needs, or will it get all the power supply provides? Another option would be to supply it with a benchtop power supply I have, though I worry somewhere along the line it might get joggled, and would spike the device.
Re: Netbook adapter/power supply
del schisler
did you look on ebay for your power supply, i got one for a friend on their , just a thought, the voltage has to be the same the current doesn't matter all that mean's it can draw that much current before the transformer over heat's or blow's fuse . i don't know the make or model or i would look for you , his new in the box power supply was around $7.00 with free shipping , not bad , i would look their , are you sure the voltage is 19 volts? maybe 9 volt ? look closely . that was what his was , i been in repair sence 1949, but retired now , good luck
Re: Netbook adapter/power supply *LINK*
Bob Entwisle in NJ
Using a higher current supply should not be a problem.
And those supplies seem to be pretty prolific on the web. Here's a link to one, and there are lots of other suppliers out there.
Bob in NJ
Netbook power supply
Tom
Thanks all.
I did find them on the bay, ut that stuff takes weeks to get here. The best deals are from china as thry have free international shipping. Don, t know how they work that, but it takes a month to get here. Plus ebay has again managed to mess up US to Can. shipping witth their GSP system.
John McGaw
Am I correct in guessing that you are in Canada? If so, you can order something that will work from amazon.ca and they should be able to get it to you in no more than a few days even if you are snowbound at Watson Lake. Example: go to amazon.ca and do a search for "universal laptop power supply" or simply enter a direct search for whatever brand you have. All of them are common as dirt and are usually quite cheap.
Robert Fuller
Contrary to the thought that more is better, a higher current power supply may NOT be better. If the batteries are Lithium Ion, a higher charging rate will cook them in no time.
This being said, there may be current limiting circuitry inside the netbook that will prevent the batteries from being overcharged, but I would not risk it.
Check online for a direct replacement (be sure the polarity of the charging plug is correct).
Tom
Amazon.CA does have it, but they want twice-2.5 what the slow boat from china wants. Plus for that part alone Amazon would want postage. I also cancelled my credit card at Xmas, because of target and a habit of doing so every now an then. I'm not in a rush so I will just wait, but if I could sort out a replacement I would do that for now. Gratefully taking all the suggestions into account, I doubt I have the info I need to McGyver something. Thanks all.
