I have not ever really worked with MDF before and have a few questions. I am making a table top using an Solid Core door and the center of the door is MDF. After cutting to size on my table saw, I see that the MDF has a rather fuzzy surface. What do I need to do to be able to glue hardwood edging to it? Also, when I attached the table top to the table shirts, is there anything I need to consider when screwing into the MDF? I would assume I need to pre-drill?
Not all MDF is created equal so the prudent thing to do is a test on some actual samples. However, regular good PVA wood-glue will probably do the job just fine for gluing hardwood to the edge
Driving screws without a pilot hole is not a good idea, MDF is hard and it will also pull-up the fibers being displaced for the screw making a bump.
The real caution for using screws or nails with MDF is when working on the edge. MDF is really many layers of paper-like material compressed. When you drive a screw into edge without a pilot hole the layers will very easily separate (split).
I'm wondering if using Confirmat Screws would be prudent. I know they're the thing for particle board but, not having any experience with screws in MDF, would they work in MDF as well?
I have limited experience with MDF. OTOH, I ahve cut up a used several doors as you describe.
If you cut it with a decent blade leaving a flat/smooth surface, yellow glue will work well. Coat the surface well and apply enough clamp pressure to close the joints and create some squeeze out.
Bill is right about the construction of MDF. It looks like a complete random homogeneous product, but it is actually in paper like layers. If you glue a piece to the surface (not the edge) and peal it off it will pull the surface off the MDF.
I would predrill for all screws and use screws with coarse deep and sharp threads.
If gluing to the cut edge you might consider brushing a thin coat of glue to the edge, waiting a couple minutes, then brushing a wetter coat on both surfaces and clamping them together. I use this approach when gluing mitered MDF edges with plastic resin glue, taking advantage of the long open time. If you are using white or yellow glue there is a shorter open time.
You might consider screws into the MDF parallel to the surface to be like screws into the end grain of solid wood - they won't hold nearly as well as screws perpendicular to the surface of MDF. I predrill in both directions for screws into MDF, and generally use drywall screws with their deeper thread and thinner root for MDF.
Hopefully you still have the cutoffs from the door that might allow you to experiment with the MDF first.
I used 7X50mm Confirmat screws to do a wall of MDF bookshelves and it worked out very well. Very strong, very rigid. The only downside is that the screws really want to have holes pre-drilled with a special and non-cheap drill bit.
I've not had any problems using standard PVA glue for edge gluing MDF. Surface gluing for lamination can be a bit of a problem because the glue far from the edge never seems to dry but that is not done often. My bookshelves used wide maple edging on the movable shelves and these were glued on with PVA and biscuits just to make sure that they were rigid enough.
I will be gluing hardwood edging to the MDF sides and screwing into the flat surfaces (perpendicular as you describe) - basically attaching the top to the table skirts. I just finished testing gluing some hardwood scraps to the MDF scraps and it worked fine. Was considering using pocket holes in the skirts to attach the MDF top. I can still pre-drill through the pocket holes before using the screws. Should I be using fine thread or course thread for this?
When you need to use a screw in MDF, that really needs to hold better than you can expect the screw to provide normally. Drill a pilot hole, then go ahead and drive your screw in each of the holes for a dry run assembly. Then take it apart and lay it flat, so you can flood the hole with thin cyanoacrylate glue. This will wick out into the surrounding fiber, which will become a nice solid plastic plug, which you will need to drill a new pilot hole into before you can get a screw into again.
There are a lot of nylon insert fittings on the market for almost any fastening situation, which usually require special metric drill bits for, but the CA soak is a handy option too, if you are not already geared up for the other stuff.
A word of caution though, MDF I'd good in compression, not bad in shear, but poor in tension, and shock loads. So don't try to lift this by the top, if the base is is heavy and hanging from it. A tiny bump can tear out a big plug around any fitting. This material is harder on both faces, than in the middle.
The fuzz is a problem. I haveused MDF mostly for forms and jigs. IT sands great. On stuff like guitar forms I put the drumsander in the drill press and bark back pretty heavily from the BS cuts. You might try triminh with a sharp router bit.
