Is shellac corrosive?
I had a can of Zinser Seal Coat sitting on the shelf way too long. One day I noticed a sweet smell and found it leaking. I set it outside, but have not opened the can. Does this happen often? Never occurred to me "shelf life" might mean it would coat your shelf years later.
Re: Is shellac corrosive?
John Pappas
Had the same thing happen to me several years ago. Subsequent cans have not been a problem.
Jerry Gibbs
They make medicine pill capsules and shoe wax from shellac. Unless Zinsser added something, I would be surprised if the shellac is corroding the can.
Bill Howatt
I agree, it isn't the shellac stuff itself but the solvent. Maybe some type of alcohol is corrosive over a long time or maybe an additive.
Bill
Clint Searl
Only if you drink it!
requirements to dissolve/rust steel
Background: ethanol adulterated gasoline can not be pumped through pipe lines because it will corrode the steel. The ethanol is mixed along with additives at the terminal before delivery to stations. The chemistry behind corrosion and the chemistry running a battery are the same, with the same requirements.
There are only two requirements necessary to dissolve and/or rust steel.
For iron to dissolve or rust it must give up some electrons from its atoms. They have to go somewhere. Something has to accept these electrons. We call this stuff the oxidizing agent, corrosive agent, or electron acceptor. The most common and prevalent of these chemicals are oxygen or any acid.
Second, the solution must be conductive. Water and alcohols are sufficiently conductive to enable corrosion.
We most commonly stop corrosion by making the surface in contact with the metal non-conductive by painting it, greasing it, waxing, etc.
In the beginning the can was coated with something, epoxy or something similar. Over time the coating got breached. The alcohols used to formulate shellac are sufficiently conductive. A partially filled can has lots of oxygen in the head space. No doubt you also left the can open for some time and the solvent picked up additional water from the air. I think I read somewhere that shellac is acidic or it becomes so.
So all the ingredients are there to rust the can as soon as the steel's protective coating is compromised. Don't stir with a screwdriver next time. Alternatively, over time oxygen and water diffused through an inadequate coating, initiated a rust spot, that in turn bubbled and delaminated some coating and corrosion took hold in earnest from there.
It is soluble in alcohol
Re: requirements to dissolve/rust steel
Jerry Gibbs
sounds like the solution is to use it up.
Dick Coers
Thinned shellac can really wreck an aluminum canister on the spray gun as well.
William Duffield
It's happened to me, too. I now have hardened brown puddles on two shelves and the floor below.
See Bill Tindall's explanation. He makes a lot of sense. I think I'll go put some Bloxygen in the top of the new can of Seal-Coat, and when I need to extract some, I'll use a disposable pipette. That'w what I've been doing recently with other reactive finishes and adhesives.
disposable pipette
Jerry Gibbs
Can I make my own, like a finger over the end of a plastic straw? What is the capacity of the pipettes you buy and where do you buy them? I could have used some when I was mixing stain colors.
Re: Amazon
William Duffield
These are the ones I use. They're the cheapest I could find, at 3¢ each in quantity. It'll take me quite a while to use 500, so I share them with friends and family.
http://www.amazon.com/Karter-Scientific-206H2-Transfer-Pipettes/dp/B005Z4QVMW/ref=sr_1_8?ie=UTF8&qid=1387663654&sr=8-8&keywords=pipette
They work for small quantities of epoxy resin and hardener, BLO, Waterlox, Watco, polyurinate, pigment stains, dyes, Titebond (but not the molding and trim glue), liquid hide glue, hot hide glue, etc. They're disposable, so you don't have to worry about cleaning the goop out of them.
An advantage when using hardening oils in small quantities is you don't spill any expensive and invisible argon, and you don't have to worry about how you are going to clean all those marbles when you finally use up the finish. :D
If I were transferring shellac cut with everclear :D , I'd take a chance on using a straw, but not if there were a chance of ingesting methanol along with the bug spit. I've used the thumb over the end of a straw technique, but I often spill the transferred liquid, and don't have the control of quantity that I would like.
The Real Solution
is to mix your own in small batches sized to the job at hand. You then have complete control over strength and cost as waste (the stuff goes bad as the resin esterifies) is reduced. and you don't have to worry whether the stuff has gone south in the can.
It's also easy to hold in a glass jar.
Rather than
wasting Everclear, use Parks DNA. They only use 10% methanol as opposed to KleenStril and the others that are typically up to 50% methanol.
Re: Is shellac corrosive? yes in metal can's
del schisler
Don't try to store shellac solution in metal containers, it is corrosive. if you want to read more about shellac go here
http://songbirdhd.blogspot.com/2012/05/spraying-shellac.html
Re: MOISTURE IN CAN
Howard Acheson
Was it an unopened can? The alcohol solvent in shellac will absorb moisture from the atmosphere and long term contact with metal cans will lead to corrosion. I think Zinnser now coats the inside of their cans to minimize corrosion.
Also, the shelf life of Zinnser shellac is three years.
Me too!
