Anyone here use Wool Lube in the finishing process? At what POINT is these product used in the finishing process I use General Finishes wipe on products. Does it give the furniture a smoother feel at the end the finishing process?
I use wool lube as the final step in finishing if I want to knock down the level of gloss of the finished surface. I use Libron 0000 steel wool; the lube (which seems to be a liquid soap which can be extended by mixing with water) just helps the rubbing process go easier by suspending the "dust" in the liquid and extending the useful life of the steel wool. Actually, I usually use wax as the last step after the steel wool. You might want to try some liquid dish soap, the lube is pricey.
I am going to take a stab at answering this question. I don't know what wool lube is but a guess is that it is some sort of wax used in conjunction with steel wool. 4/0 wool and wax is a common last step in finishing furniture. Any wax will do- Simonize, or any of the other furniture paste waxes. The result will be a silky smooth surface and a low gloss sheen.
The finish needs to be thoroughly cured(hardened) before this step. A soft finish will not respond well. Wipe on varnish may be too soft....I don't know as I don't use it.
Like Bill, I don't know what "Wool Lube" is, but when I am wanting a "soft sheen" I also just use 4-0 steel wool with furniture wax. I have used many types of furniture wax (often what is on sale) and have seen very little if any difference. I have used this technique on Belhens lacquer, Shellac and Poly with (to me) great results. I doubt the wax adds any "protection", but I really like the feel and appearance of the waxed surfaces.
