craftsman band saw
craftsman band saw
craftsman band saw
Ronnie
I have an old, 20years or better, Craftsman 12 inch adjustable angle band saw without all the electronics and it is knocking bad. I took the blade off and it still knocks so the top wheel is not the culprit. I loosed the tension on motor belt still the same. The set screw on the bottom wheel is tight but I can't see any way I can get to the other pulleys with out taking every thing apart. Do I need a new motor or maybe..... a New saw. Can anyone help?
Re: craftsman band saw
Keith Newton
Good that you have eliminated the top wheel, which also rules out a kink or crack the blade.
Make sure that when it is up to speed, that the rubber tire is not loose and sending a flap out hitting something.
Now take the belt off, and see if the motor is out, and if there is a flap on the belt.
Then turn by hand, and find where the wheel is touching something, but that would be a scraping sound.
A broken out piece of pulley will also make a bumping sound.
Ronnie
Thanks Keith,
I checked out everything on your list and when I was spinning the wheel I could hear something, there was one distinct place in the turn of the wheel where I could hear it but could not feel anything,same thing on the pulley side and still couldn't feel it but the motor without belt just hummed. Could it be the bearings in this assemble everything feels tight no slop that I can feel. Whats got me is that it's just that one place.
Keith Newton
Look more closely on the back side away from you, especially if there is something sticking down close to the back edge of the wheel.
Also, take the wheel in both hands, and feel for any looseness by pulling out, lifting tilting on several axis.
Are you saying that your sure it is in the bottom wheel. One thing that had me for quite a while when I had one of those, was the little blade guard on the front of the bar which holds the guides, somehow got whacked, and would touch the top wheel in one spot on each rotation.
del schisler
could be a flat ball in the bearing , put a mark on the wheel and on the case and see it it make's the sound each time and same mark's line up, may put the belt back on the motor and turn it on with just the bottom wheel and see if it make's that sound when the marks line up, probly a bad bearing good luck
Ronnie
Thanks guys, I have the parts diagram and there are two bearings on each wheel, the top one wouldn't be that much that much trouble but the bottom one that must be bad looks like it would be a real pain to get to. I'm thinking I'll just not use it unless I have too until it warms up a little it's been cold here.
