Repairing Dewalt 733 planer questions again
I have been working on my Dewalt 733 lunch box planer. I was sort of lurching or stopping or and instant and leaving a line on the work. Several suggestions were made and I ordered the drive chains and then the bushings. This morning I installed them. Two or three observations.
At first glance, the new chains appeared identical to the old chains. Until I put them on. whatever slack was there is gone now. Also, one of the old chains had a stiff link or two and that may have been the problem or at least part of it.
One of my four bushings was clearly worn. I replaced all of them. I did not measure, but there may have been wear in the others as well.
And, lets hear it for the impact driver. I have a 12 volt Bosch impact driver. Fortunately its compact. I tried removing the various screws by hand. soaked them with PB Blast. Couldn't budge any of them. Stuart Johnson had told me they were tough. The impact driver zipped them right out like nothing. Definitely the tool for that job.
Now for the question. I have a spring left over.
Its about 1" long and .4" in diameter, The first I ever saw of it, it was resting on the floor about 18" away. It appears to be part No. 169 and is directly above the spring labeled 73 on the diagram. It appears it would go into the same hole as the spring that holds the roller down. I can't figure out why there would be two springs. They probably would fit one inside the other. Concentric springs does not seem like a good idea. And, three of the four bushing springs are No. 73, but one is No. 58. Any reason to believe they are different? They looked the same to me.
Should I take it apart and try to put the extra spring into the hole or what? Who would have a definitive answer?
