Cleaning hardwood floors
Joe in a Cleveland suburb
Hello all.
I have a hypothetical question.
Suppose you know some guy who has oak flooring in his kitchen - the original T&G flooring put in when the house was built in the 1920's. They were sanded and refinished 10 or so years ago. This floor should have been re-done several years ago due to high wear from dogs, kids, and so on. This loser guy kept telling his wife he would get it done and hasn't done it yet. What a jerk.
Couple years go by and the wear gets so bad there are areas where the finish is worn off and dirt from dogs and stuff has reached into the crevices of the wood.
Now this moron of a husband finds out his whole family is coming for Christmas and he is trying to figure out how best to hide his utter laziness. Pfft, what a loser, right? He has even tried resorting to calling floor finishing companies to see if he could get his floor refinished before Christmas. They just kinda laughed and said no way before Christmas. What a desperate clod he is. Sheesh.
Short of using throw rugs to hide the mess, if you knew this loser of a husband, is there a cleaning method you might suggest to him that would clean out the nooks and crannies of the wood of ground in dirt?
I tried, er, I mean he tried, a nylon brush and general cleaner. No luck.
Any suggestions I could pass along to this clown?
Thanks.
:D
Re: Cleaning hardwood floors
Rent
a buffer with green scrubber pad(s).
Use Murphy's Oil soap + water to wet the floor.
Scrub then mop off the gunk with clean water.
Repeat 2 & 3.
Allow to dry.
Vacuum well, then apply 1 coat of Bona Mega [water-based] finish. Keep the dogs and furniture off for 2 days, walk-on in sock the next morning.
Make appointment with refinisher for next year.
[Git movin', Slacker! I hear jingle bells . . .]
Jesper, Denmark
Re: Sounds like a good plan to me......
Jesper, Denmark
Depending on the result after the first lot of soap and water, he might just try a second coat with a higher concentration of soap - say two cups of soap in a bucket of hot water.
This might be OK for the party at Christmas, so he can have the floor professionally done in January. This risk is that if he finishes it now, it will not get done in January.
I have pine floors from 1928 or so. They are unfinished with the exception of a heavy soap wash every two weeks or so.
Call in the MARINES.
basil
This was how it was done in the second battalion barracks at Parris Island in 1964.
Guy up front with a bayonet picking large objects and dirt out of wide cracks. Guy behind with toothbrush scrubbing dirt out of all the cracks between boards. Another behind him sweeping up the dirt. Have a poor soul with a pale of water, scrub brush and a bar of OCTAGON soap scrubbing the floor behind him. Then the fresh water guy rinsing and behind him, one drying the [s]deck[/s] floor.
Now line them up about 10 abreast and have at it.
Before reaching the other side have rest of the platoon fan floor until completely dry.
Before they all get to the other side, have one person pour 5 gallons of wax on floor and one spreading it with a mop.
Turn idiot loose with buffer and listen for loud bangs against wall.
Who needs a finish on a hardwood floor when you have man power and wax.
Honestly, if just cleaning will do, I would use a strong solution of Murphy Oil Soap.
Murphy's Oil soap
basil
Dang, I should have read your post before posting.
Murphy's Oil soap is an excellent product. I've used it for cleaning walls, floors, furniture, just about anything wooden. It works on other stuff too.
Getting hard to find it in my small town. Bought the last bottle WALGREENS had yesterday. No one in town carries it any more.
I still vote throw rugs..........
Dick Coers
for this shindig anyway. There's enough stress at Christmas. Cover it up, refinish at your leasure. (like in the next 5 years or so) That was my plan for Thanksgiving at our house.
Do nada
paul in AZ
Nobody is going to be paying attention to the damn floor anyway.
Schedule the refinisher for January and be done with it.
Sounds like a plan. Do nada.  Til next year, again
Joe Grittani
A friend recently had new oak flooring fingernail jointed into old flooring and then the whole thing sanded
and covered with three coats of polyurethane. The floor looks great. But,the written instructions she was given by the finishers specifically said DO NOT use Murphy's Oil Soap to clean it because of an undesirable chemical reaction between it and the poly.
Joe
What kind of "poly"?
I've had my floors redone with three coats of Bona Mega and my guys specifically recommends Murphy's after the floor has cured for at least 2 weeks.
tia
And
Ol' Slacker will hear about how he wrecked Christmas for SWMBO and everyone else for the next 6 weeks.
"Pass the gravy but don't worry about the spills, dear. They'll blend right in with the floor that your woodworker father promised me he'd refinish before the holidays."
" Not to worry about those spills, the dog will clean'em up and what's left will get taken care of after hot shot gets off the couch next year."
:D :D
I recently refinished mine. Mine had the Vee grooves, Its Bruce flooring about twenty years old. The finish failed within a moth or two. The slacker that lives in this house put it off until about a month ago. Dreaded those Vee grooves. Turned out they were fairly easy, just sat down with a hook scraper and scraped both sides of each groove. 200 Sf of flooring took about two hours.
My advice to fellow slackers is to put it off until after Christmas. My reason is that I put on three coats of Urethane and with the house closed up for winter it took at least two weeks, probably three for the smell of the finish to dissipate. It was not bad, at least to a wood worker, but it does not mix well with turkey, beef, ham or eggnog. Buy some throw rugs.
Additional advice. I made several mistakes. One, my floor was pretty beat up so I decided that leaving some of the wear and treating it as patina was a good idea. Not And they tell you to clean the floor after each coat in preparation for the next. what they mean is not just clean, clean room clean. For my lat coat, I sanded and vacuumed. Not good enough. Should have used a tack cloth too. I have a Jurassic park of dog and cat hair in mine. Actually not bad but a real pisser after all the work. I can't stress the clean part enough. I used a lambs wool applicator recommended and marketed by the finish. Got some of that in the floor too. Did I mention CLEAN? Someone posted what looks like a much better applicator. Prompt me and I will send you the link. And get it clean.
Throw rugs it is.
Murphy's really worked. Cleaned the floor really well, but left the floor gray where the finish has worn off.
Throw rugs it is.
Thanks for all the suggestions!
