Band Saw Sharpening demystified
Brad Bransky
Having read numerous exotic methods for sharpening band saw blades, I tried the simplest method I could think of.
My Timber Wolf 3TPI, 93.5” band had cut many feet of quarter sawn white oak and had become so dull it would hardly cut 1.5” red cedar.
Here’s what I did during half time of a collegiate basketball game.
Dremel at 5000 rpm with a chain saw sharpener, $6+/pkg of 2 grinding rods.
Put the spinning grinder into the gullet under the hook and tip perpendicular to the gullet (no angle cut, just straight across) and ground forward through the gullet over the tip and out-one smooth movement through the gullet and out over the tip.
That’s it! Surprisingly, believe it or not, it became sharper than when new.
Brad Bransky
MPMA ‘57
Re: Band Saw Sharpening demystified
Try it with a 12 tpi or 16 tpi blade. [grin - no smiley face buttons on my iPad]. If one doesn't have a Dremel, one of those small DMT stones on a paddle will do the job, if you are desperate. I find this is more practical on my 12" bandsaw than on the 18", but then the blades for the 12 are also a lot less expensive, and replacement thus more justified.
If you want to add a little fleam, just tilt the table and do every other tooth, and then tilt it the other way and do the rest of them. If your table only tilts one way, you'll have to build a taper jig. What makes this trick work is that you slide the sharpening "stone" across the table, while applying downward pressure to the tooth with a finger in the upper wheel.
