Qustion for those who build Chests of drawers
I am tasked with building a chest of drawers for my nephew. I paln to make the sides out of solid walnut about 13/16" thick. I need a front corner detail. Not sure why I am stymied, but.....
Anybody got a suggestion of how to make the front corners of the actual chest?
Re: Qustion for those who build Chests of drawers
Start with the overall look you want
... then figure out how to build it. There are lots of possibilities depending on what you want the front elevation to look like, how you propose to handle the legs/feet, etc. Are you looking for design ideas or construction ideas?
For Example . .
Do you want overlay or in-set drawer fronts? [Think "face-frame vs. Euro-style cabinets]
Dick Coers
google image search is valuable when stuck on design questions. When using solid sides, remember seasonal wood movement. Any dust panels, drawer slides if you use them, etc.... can limit movement and cause trouble.
BrianMonumentCO
Not to be completely obvious.
But what style is this chest supposed to be?
That may well drive the answer.
David Yoho
Not sure what you mean, Barry. Years ago I built a chest of drawers along with a chest-on-chest from walnut. The chest of drawers and the lower chest of the chest-on-chest had something like I think you are asking about. The upper chest of the chest-on-chest was simply drawer dividers connected to the solid sides with dovetail joints. Below are some pictures that might help.
iew
New Yankee Workshop did a 7 drawer chest some years back. I have had the video for a number of years but have lost plans. I just never got around to doing it. Might be worth a look.
I was wondering if the chest...
with the horizontal frame members let into the sides with dovetails would have the racking resistance needed.
I looked at Norms Shaker chest and that is what he did. Back in season one. Wonder what it looks like now?
They want this to be very simple.
nice work
Rack-proofing
rabbit the four back edges and install a good quality (1/2-3/4") ply panel, either screwed or glued in place.
Done
This brings up weight.....
I have the boards for this skip planed to something like 13/16" Most of them are about 12" wide. I am wondering about how much to thin them down to reduce the weight of the overall chest. I know it is going upstairs and I will be on one end, at least this time. I was thinking of gluing them up to make the end and top panels and then dressing them down, but I don't have access to a larger/wider planer. The alternative is to dress them a bit and then glue them and run them through the Performax.
I actually skip planed them Last year and moved the lumber inside to acclimate so I could build the chest for last Christmas but life got in the way. I broke my hip and was hobbling around for a while. The good news is that the stock for both the chest and drawers is well acclimated. And the hip no longer bothers me. The rib is a different story.
It Ain't Heavy . . .
but you can do the same thing with 1/4" Merranti ply. Cut it tight to the measure of your rabbits, put the "good side" to the back, and stain it walnut. If you screw (the wood), keep the fixing points away from the corners.
Re: It Ain't Heavy . . .
Mark, I was actually thinking of the whole thing. Should I plane the lumber down to 3/4" or less etc. The chests I have made in the past were all frame and panel on the ends. I am wondering if the solid ends will add much weight. Mostly just musing. Thanks for the input.
I've done solid panel. The weight difference is mostly meaningless. More important is grain orientation and seasonal movement factors. As you choose the boards to make up the side and top panels, be careful to select and use the same balance of quarter to face grain so that the three panels will move the same amount. Far less critical with walnut than with stock like the fruit woods.
that is how they used to be made
You will find every quality piece of Period furniture built with dovetailed drawer runners and a dovetailed top. The wood will fracture before you can rack it perceptibly. Any design that lasts 300 years is worth considering.
BTW Barry
I may have misread your post as I somehow got the impression your chest was part of a hutch. As everybody knows, what's a hutch wit-out da rabbits . .
Aww!
Local Expert on Hoppus Feet
Thnkyu,thkyuvermuch, I'm here all week
