trimming tape veneer
Jerry Gibbs
I have edged some plywood with iron tape veneer. The veneer is birch. I have trouble trimming the veneer even though I am aware of the problem of the tape splitting into the good section. I know there are gizmos for trimming the tape cutting both sides at once. Do these tools cause any issues of the tape splitting or tearing where it is not wanted? Thanks- Jerry
Re: trimming tape veneer
Can't answer your question, but I await the answer, because I want to know also. Trimming the veneer is harder than it looks like it should be. Maybe the divice works well??
I have done it with a rasp. Lay the rasp flat on the surface of the material being edge and slide it along so that it presses the part being cut off tighter onto the surface. You can lay a piece of paper on the surface to keep the rasp from scratching it and then file or sand the slightly proud edge off.
And, you can use a flush trim bit in a router. Even with a laminate trimmer type router this seems like over kill, but it work well. You may have to clean the glue off the bit later, but it does work well. Its a good idea to have the work piece stable and not tip the router "into" the edge. IF you are having trouble you can clamp a second piece beside the first to double the thickness and give you a more stable base. You can also clamp two side by side with a spacer in between and then run both inner surfaces.
Clint Searl
Clint Searl
Block plane and sandpaper.
If you're thinking of the Virutex *LINK*
Henry Higginbotham
Several years ago, I built some shelving for a used book store. Cost was a big consideration, so all the plywood was banded with iron-on birch veneer tape. I trimmed around 250 feet of the stuff with the Virutex double trimmer and don't recall any problems, even though I was expecting exactly the kind you describe.
Virutex trimmer
Dick Coers
I also have the Virutex, but don't care for it with wood tape. One side is always cutting into the grain. Works like a dream on PVC tape. For wood tape, you have to work with it just like solid wood. You have to read the grain and only trim it with the grain, not against. I use a sharp chisel, held tight to the plywood and slightly skewed. After trimming, I then VERY slightly break the edge with sandpaper on a block. Pay attention, there are sometimes seams in the tape, and the grain direction may change.
Rick L
Re: best option...
Rick L
I use a short pattern cutting fence on the table saw and can trim tape veneer faster than anything out, there. 12" Just takes a block with sandpaper to give a light radius. Never seen any mention of this technique on the hobby forum or pro forums, but what do I know with 40 years in industrial shops. Most folks don't even know what a pattern makers fence is. A great shop addition that is relatively unknown to most folks...
http://www.shopnotes.com/issues/081/videos/table-saw-pattern-cutting/
waroland
I saw a trimmer similar to the Virutex at Lowes last Saturday. It was located on the back row behind the cabinet area.
That's cool
David Yoho
Thanks for that tip. Thinking back I can see how it would have been a problem solver for me. I will have to look to see if I have issue 81 but if not it looks easy enough to make and use. That's a cool idea, thanks.
David Yoho
I've used several methods for this. I have one of those double trimmers I stopped using probably 15 years ago. The method that works the best for me is to lightly run my Stanley #80 cabinet scraper over the edging until flush and finish with a sandpaper block.
Re: If you're thinking of the Virutex
John McGaw
I have that one too and find it to be quite satisfactory. I've used it on both natural veneer and melamine edging with good results.
don stephan
Make sure you round over the top edge of the edge banding, as anything being slid off the shelf will catch and pull it.
The V tool worked on PVC iron well, as a rough cut, but not on wood. I had a laminate trimming file I used on both to make flush with the surfaces.
TMac
Jerry Gibbs
Tommy MacDonald has used the raised fence several times on his show. It is the only woodworking show I get and I usually learn something.
