toxic reaction
toxic reaction
toxic reaction
eliot feldman
Parts of my skin turned red and itches like crazy after exposure to cocobolo dust. I'm using some topical steroid cream, which doesn't help much. Any ideas?
Re: toxic reaction
Re: toxic reaction
Lee Schierer in McKean, PA
Try washing with baking soda then take a couple of benadryl.
Lee
Re: toxic reaction
Re: toxic reaction
Merle
If you take the Benadryl aka diphenhydramine, be prepared to sleep and do not use any machinery. Otherwise, it is a good thing to use for an allergic reaction.
Re: toxic reaction
Re: toxic reaction
William Duffield
Stop working cocobolo! Many woods cause sensitivity reactions in some people, and cocobolo is probably the most notorious, or at least causes the most widely reported serious problems. These sensitivities often get much worse in a hurry. The next time you breathe the dust, you may end up in the hospital with anaphylactic shock.
Re: toxic reaction
Jesper, Denmark
Re: I'll second that....
Jesper, Denmark
Stop working with Cocobolo. Don't take any risks with potential anaphylactic reactions - they can be seriously life threatening.
My case was not relate to turning, but to a relatively benign medication. My left half of the tongue swelled to the size of a tennis ball - fortunately only the left side, or.......
Re: toxic reaction
Go to the doctor
Dick Coers
and get a shot. It will reduce the misery time by half. At least it works with a poison ivy rash.
Re: toxic reaction
R Payne
Also a good idea not to work other related wood species.
ron
Re: toxic reaction
Jason Roehl in Lafayette, IN
Fair warning!
Everybody reacts differently to Benadryl (and any med for that matter). I've found that I can take one Benadryl at the recommended interval and be just fine doing whatever. If I take two in the evening, I will be out cold for 6 hours, then wide awake, with no memory beyond about half hour to an hour after taking the Benadryl.
Jason
Re: toxic reaction
Re: toxic reaction
eliot feldman
Thanks for all the advice and concern. I took some Benadryl and kept using the steroid cream, and it's getting less bothersome. That cocobolo sure is gorgeous wood though!
Re: toxic reaction
Re: toxic reaction
walta
Please find someone that is not sensitive to cocobolo to decontaminate your shop.
It has been said “There are two kinds of people those who are allergic to cocobolo and those that will be with enough exposure.”
Walta
Re: toxic reaction
Raven907
Re: toxic reaction
Raven907
I am not sensitive to cocobolo or any of the other rosewood species...yet. I intend on keeping it that way. My understanding is that once you develop a reaction, it carries over to other woods that you have never had problems with.
When I work rosewoods, I take precautions to keep me from contacting the wood or the dust. I wear nitrile exam gloves. Check them often to make sure they don't have a hole in them. I run the dust collector and immediately vacuum up the dust and debris left on the machine. I wear a respirator and make sure it fits well. That means a fresh shave and make sure I have a tight fit to my face.
