Google Chrome questions
I have been using Google Chrome for a while. Technically, I know almost nothing about it or how it works.
Some how it has gotten infested with Ask.com. In the bar under the tabs in the initial tab, if you type something in to search for, it goes to Ask.com and not Google. I assume somewhere along the way somebody click on YES for ASK as a preference. How do I set it back to Google.
The same of=r a similar question applies to a friend's computer at the office, except that the entire first tab loads as LavaSoft. No one is confessing to setting it. I have never heard of Lavasoft. So, how do we get that out and go back to just Google?
Re: Google Chrome questions
Jason Roehl in Lafayette, IN
The ask.com toolbar was probably added by Adobe or Java when you updated one of them (can't remember which does it). I always read through the update windows, and make sure that I select to notify me for an update, rather than the automatic update. Then, when they do need an update, I have to make sure the "Install Ask.com toolbar" box is unchecked--which is always pre-checked.
Another thing to check is under your Windows Control Panel, go to Programs, and look through the installed list for various toolbars. Proceed with caution here, and at your own risk. I easily recognize out-of-place items in general, but not everyone would.
Jason
Manage search engines
Click the toolbox icon at the top right of your browser, select Settings, then Manage Search Engines. You can delete them and/or restore Google to your default setting.
If that doesn't work, you can go to your Control Panel and Add/Remove programs, then look for and delete the offending app.
Philip Duffy
You can also to to "settings" in the upper rt corner and Cut or Delete those you do not want to see from the list. Phil
Jim DeLaney, Austintown, Ohio
Once you've gotten ASK removed, remember that you don't need a search toolbar in Chrome. All you have to do is type the search term in the address space, and it'll take you right to Google.
David Yoho
Jason is right about how you got the Ask Toolbar on your computer. You should be able to uninstall it as mentioned by others.
Lavasoft is the maker of Ad-Aware anitvirus and anit-malware program. The other replies should help you change your default search engine back to Google.
It only took me....
two days to find the menu or whatever it is. Who knew those three little hash marks meant something? I think I got it. I was having to just leave the opening tab blank and go to a second one to avoid Ask.com or select Google search and then use it. A minor but constant irritation.
Thanks
