Is there a hinge?
Is there a hinge?
Is there a hinge?
Steve V
I am working on a dvd case where I have a 24" space to fit it into. I want to make it as two 12" sections and be able to open one side where it folds onto the other half, allowing access to a space behind it that this case will be hiding.
Since the case is 6" deep, what type of hinge can I use so that I can open one half so that the back end will clear the wall when opening it? Is there some type of hinge I can use or am I going to have to create an 1-1/2" filler on the front so that it allows for the back end of the unit to clear the wall?
Re: Is there a hinge?
Keith Newton
I can't think of a hinge that will do that.
The filler strip idea you mention, will need to be part of the first side to open, or it will be an obstruction as well if it is part of the carcass.
If you can reduce the front to back down to 5", it will only need 1", if that helps.
John McGaw
After reading your question several times I find myself unable to picture, even roughly, what you are describing. Perhaps a rough sketch might help clarify the overall layout, the moving parts, the hidden space, etc. An idea of the weight involved would be good too -- hinging a couple of pounds or a couple of hundred are radically different things. There are an amazing number of preexisting hinge types and some of the 'European' cabinet hinges allow some seriously strange movements when they unfold.
Steve V
Thanks for the posts.
Good point about the weight. I should have mentioned it because it is important. The Box with shelves I would estimate to be about 10lbs. Filling that with DVD's or CD's would add to it but I wouldn't imagine it would be more than 50lbs.
I'm not sure how to post a picture though. The easiest thing is to picture a book case. Now make it only 6" deep and 12" wide (height can be 4'). I want another bookcase the same size attached to the other while they are side by side so they fit in a 24" wide opening. I'm wondering if there is something that will let me hinge one of them without having to make one 10.5" with a 1.5" front filler so that the rear clears the wall of the opening it's in.
The only thing I can think of that might work would be to make an arrangement that would allow the DVD case to slide forward out of the surrounding cabinet and then hinge. There are all sorts of rails that would allow this, but I think it would take up as much space as the mullion strip necessary tom make the regular hinges work.
I think you are making a basically hidden compartment. You might Google that and see what others have come up with.
Re: Is there a hinge? *LINK*
Would this work?
Soss
Can you just angle the closing side?
Steve V
@Barry,
I was actually describing what I'm doing a bit more simplistic than I embarked on. I'm actually filling up a 48" wide area with two sets of 12" cases hinged to each other and one of the cases of each set is attached to a linear rail system, so you can open one 12" section onto the other section and slide them out of the way, giving full access to the shelving behind.
I had looked into doing this at first like you mentioned where I could just make two 24" sections and be able to slide them from to back and left to right to access everything behind it, but there wasn't a good way to do it without it looking extremely inductrial.
Thank you for the reply, I appreciate it.
Steve V
@Everyone who responded.
Thank you for the suggestions. I had looked into some of them prior to my post (Got ideas for future projects especially with the Soss hinges :0 )
My main concern was creating a filler, then finding out there was some type of hinge I hadn't come across.
I think the cleanest and easiest way will be to make the filler.
Thank you all again! Hopefully I'll be able to post a link to a finished picture in the next couple of weeks.
Steve
