Oak (wide) floor deck/landing
Larry Rupprecht
A close friend asked me to build and install a solid oak landing inside their patio doors. The doors had to be elevated one step above the inside finished floor and a very solid plywood deck is already installed to support this oak landing.The landing dimensions are 84" long and 30" wide with a radiused outer profile along the 84" length. The 30" width at the center gradually decreases to 19" at the ends of this piece. I chose quarter-sawn red oak netting 1-1/16" thick and have begun the glue up of a solid panel 30+" wide.
It occurred to me that fastening this large deck will present some issues with expansion/contraction. I found state forestry tables and equations that suggest seasonal expansion for quarter-sawn red oak over 30" should be about 1/8". That dimension we can accommodate with a 3/16" wide joint against the door frame that is filled with flexible sealant/caulk.
My remaining concern is how to fasten the deck to its under-support. The total weight of the finished deck will be close to 150-160 lbs. I am considering permanent fasteners about 20" out from the door, thus reducing the expansion towards the door by 1/3. These fasteners can be screws with grain-matched plugs sanded flat with the surface. At the door jambs - both side and center - I would put a stop that would function like base shoe on base molding does for hardwood floors, providing some physical hold-down but only at the three locations and only about 3" wide at each spot.
Hope some experienced readers might comment of how well this plan will perform or offer some better ideas. Location is Minnesota, patio doors face east, and the doors do not open during winter months as this is simply a sun-rise room off their master bedroom.
Thanks in advance for your comments....Larry
Re: Oak (wide) floor deck/landing
Keith Newton
Just wondering why you want to glue it up into one solid panel? Is there a reason why T&G on the narrower planks won't work?
If it has to go down as a solid panel, I'd think about bonding with something that has a lot of stretch, then floating it high on shims, so it won't shear off. Something like those little domed cabinet door bumps would hold it up, and maybe silicone could do it.
While QS isn't prone to cup from normal drying stresses, if there is direct Sun on it, warming the surface well above the ambient air temperature, it may cause the face to give up more moisture than middle and bottom, building some cupping tension. But that is not a really strong force.
Another solution, wouid be two mill several T-slots across the bottom, stopping shy of the outside edge. Then mill a matching piece which can be screwed down to the sub-deck, then sliding it onto them. A couple of bunged screws near the doors would keep it tight there, allowing all the movement to be over on the overhang. I use this on large solid table tops often, and have never had any problems..
Larry Rupprecht
Keith,
We decided on solid so the edge could be a simple bull-nose appearance and no T&G joints showing. I know this added a bit more complexity but the customer, especially one's good friend for 50+ years, is always the Boss.
I like the mating with a T-slot idea.....pretty sure this can work to our advantage. This would allow solid hold down and get the expansion onto the outside edge where it won't be noticed or create a seasonally large gap at the door frame.
In fact, I'm going to the scratch pad tonight and work this idea out.
Thanks for the idea.
Larry
Keith Newton
Larry, I thought I would find the cutter I use, but couldn't. It is somewhat like a rabbit cutter, but without the bearing on the bottom. After routing a straight slot across the bottom, I put the cutter on which cuts the wings, letting the shank act as a rub bearing over the cutter. I scrub that area with a paraffin stick, to lubricate for the shank friction. I lubricate the T bar and the slot with same after it is all prepared.
However, you can use a large dovetail cutter, but they just don't slide as easily.
