I need to replace the extension table on my delta unisaw. I didn't see much posted for others doing this job, so I thought I'd ask. Any suggestions out there? What is the best for endurance/longevity...ease of installation would be good, as I can be a bit of a hack!
Probably because many of us limp along with the original or have a different design.
I am presuming you are talking about the side extension table rather than an outfeed table.
Some suggestions:
Formica is the least expensive. I have seen people who have made their own Formica tops by gluing together 3/4" plywood sheets and covering them with Formica. You can get sheet Formica at a reasonable price and edge band it with hardwood for durability.
Melamine coated plywood - works well if you can find it.
Melamine coated MDF - can work reasonably well.
Melamine or Formica coated particle board - I really dislike particle board.
Corian or similar counter top material - durable, lasts forever. If you can contact someone who makes kitchen counters, you can sometimes beg offcuts or pay for a partial sheet that they can't use. You will have to prepare a sturdy apron. Glue just pops off. You can sand it if need be. Works quite well. I've seen one shop (cabinet shop) that used this and it was quite durable and attractive.
Don't know if it would apply to a Unisaw, but for my 34-444, I welded 1/4" plate to 1/8" aprons, supported by adjustable outriggers, to replace the stamped extensions. The overall width is 65".
I have a Delta contractors saw. It had grid extensions/wings.
I went to a countertop shop that does Formica type tops and they gave me a bunch of sink cutouts. I squared tow of them up to the right size and glued them together back to back so there was plastic laminate both top and bottom. This balanced the construction and canceled the warp that was already present, they came out quite flat and have remained so. Before I glued them up I routed slots in them for bolts to project out the edge to match up with the holes in the saw. Actually, this was an additional extension and I cut a router table type hole in it and use it for my router.
Later I got a Beismeyer Fence and it would not work with the grids. Took the grids off and filled in the space between the ribs with 1/4 plywood. Epoxied them into place. Ran them through the Performax to flatten the top and laminated the top of One. The other one I bolted the router extension back on and laminated Formica over the whole thing. The Biesmiyer Fence slides very nicely. After about five years I have some slight wear where the pad under the fence slides. A little more attention to keeping it clean and waxed would have been better.
