Your sculptural frames are really unusual, a tad more involved than just mitering moldings. I'd almost hate to put a picture inside them. How do you decide what frame shapes and designs will best complement the artwork? Or, do you choose the artwork to complement the frames? Whatever, they are delightful and very nicely designed and built.
Well, in these frames, I got the idea to point to the artwork with elements in the frame.
The oak frame, which is less attention-grabbing, with a rather classic shape, where the medallions (the arrows) the only uncommon part, is meant to highlight the picture.
The cherry and maple frame will go in a bathroom and is meant to be the focal point of the decor. The rest of the bathroom is cherry and some other light woods. The picture is less important there, being a simple "sunset" photo, which is the theme of the other pictures in the room.
Bill and Howard, thanks for your kind comments and your interest in my technique. I don't have any production photos, however and, frankly, I don't think there's anything especially novel about my methods.
I will say that there are no inlays (except for, maybe, the circular doodad in the maple overlay). All the "piping", if you will, is bent lamination. I plan everything out on CAD and print templates for the curves, which I paste on the wood, to cut and sand to.
The limited joinery consists of splined corners and of metal studs (finishing nails with the heads cut off), surrounded by a wooden dowel sheath to mount the maple overlay 5/16" off the cherry base frame.
..And, kindly, don't look too close. I don't sand to a very fine grit and my finishing leaves much to be desired. I wish I had the knowledge and expertise in finishing that you have. In fact, the finish is nothing but polyurethane buffed to 000 steel wool and waxed. I find that makes the finish pretty much disappear.
I continue to think about and work on my glue-up techniques. I think there's a lot to be creative about in that area.
I I often look at some wood object whose complexity leaves me wondering "how did they do that". Your attractive and creative frames were an example.
Nothing shabby about a varnish finish, and indeed it should be called just that. "Poly" has come to have a lot of unfavorable baggage associated with its use. I finish lots of things with varnish. Some varieties of varnish have a luster that I can't match any other way.
