I have always been in the habit of replacing the supply hoses to the washing machine about every 5 - 7 years. Washer is upstairs, and I really don't want to come home to a cascade of water running down the staircase...
I used to use the pvc or rubber ones, but today I got a set of stainless hoses. Cost was only a couple bucks more.
My question is, are these supposed to last longer than the 5 years recommended for the PVC/rubberized ones?
In 16 years of living in my house, I've only ever bought SS hoses when doing any plumbing and I've never had a failure. I think my typical water pressure is on the higher end of the normal range.
I think you can buy hoses that have a mechanical auto shut off feature in them. If the hose bursts, it shuts off the water flow.
The washing machine companies could solve the problem by moving the shut off to the other end of the hose. Similar to the Watts device above but just move the existing valve over to the faucets.
You do know that you are "supposed" to turn off the water anytime the machine is not in use? If you do that, there is very little chance of a disaster. Of course, if you do that, you would be one of the VERY FEW.
I have no data to support this but I was told that the stainless hoses provide no more protection than do non metal clad. You might want to Google and ask about the reliability of stainless steel clad hoses for washers. I have clad hoses, because I thought they provided additional protection but the latest repair guy told me (May 2013) that if a hose breaks it is more likely at the connectors than the hose within the cladding. He told me to replace the hoses every three years. By the way, he also repeated to me that turning off the water to the washer is what is specified with the washer -- although he admitted that he didn't know a soul who followed that instruction.
Interesting. I have been told some home owners insurance companies are requiring them. Of course it would be smart of the insurance company to require you to spend your money to reduce their risk, even if they had no proof it actually reduced the risk.
Some condo associations are requiring the owners to replace their water heaters every ten years.
Thanks for all the replies. I might in the future look into the shut off valve, but at $175, plus cost of an electrician to install, I figure I can buy a lifetime supply of $20 hoses every 5 years...
Next time I'll look into the hoses with the mechanical shutoff. Soudns liek a better compromise.
I had a problem with the mechanical shut-off hoses and my single-lever-type kitchen tap. Basically there is a little mechanism in the hose that closes if the water flow exceeds a set amount.
The problem was that when the tap was opened, the initial rush would exceed the shutoff limit. If the tap was opened slowly there was no problem, but a lot of the time we would give the lever a quick lift and the hose would trip the flow. To reset the hose you have to shut off the water supply to the hose. I had to replace that mechanical shutoff hose with a regular braided hose.
Give it a try, but be aware of that problem. I've never tried a shutoff hose with the washing machine or dishwasher.
ps. I suspect a braided hose will last longer than regular rubber hose, but will give you no warning before failure. My experience with rubber hose failure is that a weak spot usually develops first, resulting in a bubble forming between the rubber layers that is visible from the outside. I've been lucky and noticed the bubble before complete failure.
I use all stainless braided hoses in my house and have not had a failure in the 17 years since I installed them. Knock wood.
This little valve, made by Watts, is a very quick way to deal with turning the water on and off. One lever controls both the hot and cold water feeds. My parents used these in both their home and florida condos. The only time I shut off the water is when I'm going away for an extended time period. But for those that want to shut off the feed to the washer on a regular basis, this is the most convenient way I can imagine.
I don't use this, Howard, but I use a similar product (with a flood sensor) for the water supply to my refrigerator.
My old refrigerator was a Whirlpool with ice maker. That particular model had a nasty issue: water in the supply line to the ice maker could be frozen at the point of entering the back of the refrigerator. When that happened, the water pump kept on pumping. The result was water leaking out at a weak joint, flooding the floor. In models of subsequent years, Whirlpool put a small heater at the possible frozen location (couldn't be retrofitted to older models). I didn't want to buy a new refrigerator, so for about $100, I bought the automatic shut off valve instead.
The automatic shut off valve worked perfect. It already saved my kitchen floor a few times.
We no longer have the said refrigerator, but I'm still using the valve for the current refrigerator.
