You should have to show your Deed or Mortgage Papers to able to purchase the following:
Any sort of push pin or picture hangers.
Anything that has red dye, like red Koolade or drink boxes.
Magic Tape or invisible tape.
Bacon
(Add your suggestion here and we will get a movement going in all fifty states)
Been cleaning up a rental house and there must have been 150 push pin holes in the walls and the carpets in every room were ruined with red juice. The d@mn invisible tape is hard to see, UNTIL you PAINT over it. And I swear there was a half inch of bacon grease in the drawer under the stove. Help Mr. Clean, Help! The 409 just ran away screaming. Should have bought 509 or maybe 609.
I would suggest that your building materials, furnishings, expectations, security deposit and rental fee need to be adjusted to deal with reality. I expect that as a home inspector you have inspected homes not rented that were in a similar state.
...would be electric heat. What I suspect happens is that because the heating element is directly in the airflow of a furnace (or exposed to the room in baseboard heat), any dust/dander/other particulates that have settled on the element in the off-season burn off (the unpleasant smell at first activation in the fall), and cause a little smoke in the air. I often find that this smoke likes to condense (?) on the exterior walls near the ceilings--at every stud. They're a pain to cover with paint.
Perhaps I have led a sheltered existence as a Home Inspector. (Not) There are differences though. Most of the homes I inspect have been spruced up for the sale. Many people remove about half of their stuff if they are still living there. Some of them are staged.
I have concluded that a tenant's idea of home remodeling is to move to one some other landlord just fixed up and leave this squalid mess behind for the old land lord. I spent more time cleaning the 2 year old range than I have on mine that is 30 years old. They got some much geese inside the door I took it apart to clean it. I have used an entire can of Easy-Off. (that product may be misnamed). The carpet had what appeared to be ground in brownies or other snacks and had been drenched in red juice.
These people had a hard time. They were husband and wife and his brother who was on disability. (That check covered the rent) The wife had a good job and a part time one. The husband had a part time job and was the house husband. The Brother died about ten months in, not only taking his check with him, but they had no money to bury him. I reduced the rent to help them out and to keep them in place because I did not want to have to turn it around after one year. Then, the husband who did not have a driver's license, had a scooter accident, receiving an head injury, reducing him to nearly a vegetable. So, the wife was left without his income, without his help with the kids, and had to have help to take care of him. A downward spiral if ever there was one. Took three months to get them out to get in to turn it around. Sometimes its not about the rent, the materials or anything else.
A friend an I discussed it and decided everything should be lined with stainless steel perhaps half an inch thick and a poured concrete floor. When they move out, just go in with a flame thrower and a leaf blower, and she's good to go.
I have several houses that are thirty plus years old with baseboard heat. I just had to replace them in one house because the new tenant claimed they stink and won't stop.` I found the drywall above them to be ruined. The paper face separated from the core. Removed the apron from the window above, cut out the drywall and replaced it. Not sure what the process is, but I am thinking it just cooked ALL of the moisture out of the drywall.
Some of them were pretty much storage units anyway. One woman was a hoarder. Had EVERY piece of mail since 1987. We threw away a 30 cubic yard dumpster full of stuff.
Another one had been occupied by a woman with a life right. They lost it in a tax sale and I bought it. Astounding damage and amateur workmanship. Took two or three months to get them out of the house. Spent $30K fixing it up. They came back to look at it and wanted to rent it. Uhh, NO! I would love to sell it to them though. (Irony, poetic justice?)
I was under the impression that the core of drywall had a significant amount of water molecules locked up in the material. I order to burn it the fire must cook off the water, expending a large amount of energy. Obviously, I am probably wrong.
I have had the problem with failing drywall above baseboard heaters in at least two of my houses and a friend had it in his. I will have to start looking more closely. You might be right. Still trying to visualize how a window could leak just enough to ruin the drywall but not show up in any other way. The framing behind the drywall was fine. Hmm! Something else to think about.
After similar experiences I was happy to sell the house, although I did get a good price. After that I started advising people interesting in being a landlord that they should collect the monthly check on site so they can see the interior on a regular basis before tenants get used to carelessness and worse.
I'm talking about those multiple outlet plug-ins that allow you to overload any circuit with ease.
Also, those handy extension cords that are made of lamp cord and usually are found under the carpet or behind the bed with heaters and radios and heating blankets and such plugged into them.
I do repair work for a few landlords and I know firsthand that it is a tough occupation. Tenants are hell.---Jack
I will have to try that. I have cleaned the stove and cleaned the stove and cleaned the stove and its still greasy. As I was leaving yesterday, after having dissembled the door, I wiped the oven one more time and got BLACK off the interior. Perhaps clean is clean enough.
