A55 Smoothing Plane
Porter Cable Router Loose Plunge Post Bearing?
David Hay
I pulled out my Porter Cable 7529 plunge router last night and noticed a problem with the plunge mechanism. Even with the plunge lever fully locked, the motor rocks side to side relative to the base and posts. It seems like the bearings (or whatever rides along the post) on the post opposite the plunge lever are loose. That is, if I push slightly on the motor, parallel to the plunge posts, the motor is able to move up and down along the opposite post enough to deflect the bit at least 1/16 of an inch.
Do I have a worn out part? The router hasn't been used *that* much since I got it. Or is there some adjustment I can make? I didn't see anything obvious, but perhaps I'm missing something?
Thanks!
David
Re: Porter Cable Router Loose Plunge Post Bearing?
Ralph Lipeles
Plunge routers usually just slide up and down on a rod. There should be a bushing, metal or plastic in the router body. Maybe it's come loose and come out. I would check the parts list and then check the router against the parts list.
Ralph Lipeles
