Questions about tiled top furniture such as tables
note: if sufficient information is provided this information will be summarized in a WoodCentral Article.
What can be successfully used for a substrate? I have used 1/2 or 3/4" plywood successfully. There was one mention of cement board, but it makes a heavy substrate. Other's experience........
What can be used to stick it down with, especially to a plywood substrate?
What grout to use? What is epoxy grout? Where to get it? Experience with typical floor and wall grout with and without additives? Other options?
One problem with grout is that it takes but a tiny amount to do a typical table. What grout is available in small quantities, yet a wide variety of colors? Can "left over" grout from a floor or wall job be successfully used?
Sealing after its all finished. What to use and does it work?
Re: Questions about tiled top furniture such as tables
Whatever you use for a substrate, it needs to be very stiff, and plywood probably has the best strength:weight ratio of commonly available materials. I would not use 1/2" ply except for smaller tops, or ones that are stiffened by some understructure. I would also recommend sealing both sides of the plywood to retard moisture transfer, and glue it firmly into a surrounding frame.
I used flooring mastic from a can for most of my tile-on-plywood constructions, but you could just as easily squirt out some PL400 or other adhesive and spread it around with a notched trowel. Standard tile grout worked fine for me.
John in NM
I used to work for a welding shop that made tile top tables among other things. They used 3/4" plywood for the substrate and a mastic adhesive for the tile (I don't know which one). I don't believe they sealed the plywood, but I don't know for sure.
The few times I've done the whole job, I used plywood and whatever mastic came in the smallest tub in the tile isle of Home Depot. My wife once used regular thinset tile adhesive on plywood, and had it bow so badly that it popped the tile off.
I've gotten away without sealing the plywood, but I think I'd do that if I ever make another. Just a good practice to avoid bowing and popping or cracking the tile or grout. Easy to do with a few coats of poly, both sides.
We've always used left over grout for these projects, as even the smallest box is way too much for most of them. High quality caulk also works well, though the color options tend to be more limited and doing a tidy job can be more challenging. Almost a must for a wood surround though, I've yet to see a wood/grout joint that isn't cracked. I understand that some company is making sanded caulking intended to look like grout but stretch like caulk for exactly this purpose. I imagine it's even harder to do a tidy job of application than just caulk alone. You're probably getting the idea by now that caulking gives me problems
Grout needs to be sealed to prevent stains, or to make them easy to clean up. Porous tile as well, but glazed tile and stone tiles (other than carbonate stone) do not need sealing. I've been told that sealing before grouting makes the grout job much easier to get nice clean results. I might try that on a table or furniture job, but seems like more trouble on a floor. The downside is obviously that sealant in the grout lines makes the grout less adhesive to the edges of the tile, and easier to pop out over the years.
William Duffield
Google will provide a third of a million hits on the search term epoxy grout, including lots of tips on installing it. It is treated differently and has different (some very advantageous) characteristics than typical old fashioned cement grout.
Fortable tops, the most important might be flexibility and resistance to staining.
At the small end of the scale we are discussing, no substrate is necessary, in fact it can be a disadvantage. I've built a few trivets (you might call them hot plates) with ceramic tile bearing surfaces and a hardwood mortised and tenoned frame. The frame uses very similar construction techniques to a window pane, with the exception that the rabbets for mounting the tiles are cut shallow enough that the face of the tiles lies proud of the wooden frame.
To attach the tile to the frame, I use low temperature non-toxic hot melt glue, EVA (ethylene vinyl acetate). For further information on this, reference the link I provided in the recent thread on hot melt glue initiated by Barry Irby.
Here are a couple of examples.
I construct the frames with a small gap all the way around each tile, and apply a drop of hot melt glue at each corner and at the center of each rabbet, and simply drop the tile in place.
My reason for choosing this rather unorthodox construction is because I figured there was a good chance of spilling the pot of food that was set on the trivet, and the small gap between the tile and the wooden frame would allow easy clean up, without permanently trapping moisture and organics between the components. For the same reason, I would advise choosing a dense, stiff, rot resistant hardwood for the frame. Purpleheart is just about optimum, unless it doesn't match your color scheme.
The only differences between these and tables is the lack of aprons and legs, the number and size of the tiles you choose, and the sizes of the frame parts. They are easily scalable.
Note, I find it best to completely finish the frame before attaching the tiles.
I've built several tables using tiles using a rabbit in the edge of the hardwood frame to hold the tile just proud of the wood. One table using leftover tile that matches the floor tile in the room. 1/4" to 3/8" lip should be fine and the tile lifts out for cleaning.
Phil
Before I was a woodworker, I was a tile guy . I had some tables made, and if I remember correctly, the craftsman that built them used 3/4" plywood for the substrate. I used polished granite for the inlay. Again, if I remember correctly I used thinset mortar to attach the tiles to the substrate and standard grout to grout the installation. The tables had already been finished, so I did two things to ensure that the black grout did not end up spoiling the fine finish on the cherry surround. I waxed the surround, and then I taped it with 3m blue masking tape. This did the trick, as the finish on the cherry surround survived unscathed. Many years later, the tables look beautiful, and I expect them to outlast me.
Isn't there stuff that is added to grout to make it more "durrable"...would that in fact be, "flexible"? Seems like my tile guy gave me someyhing to add and my grout isn't brittle like mortar.
There are several potential failure modes that it avoids, or obviates. On the other hand, if the tile is struck hard enough to crack it then the failure can be spectacular, with shards and whatever struck it falling through onto the floor. Thereafter, your repair will be significantly easier than if you had glued the shattered tile to a more flexible substrate, but whoever you built it for might more likely suffer PTSD by the failure. I don't think replacement of a broken tile becomes significantly more probable.
Some advantages:
- Construction is lighter, simpler, and less expensive, and thus more elegant.
- Some time in the future, you can easily (and heroically) replace the tile with stone, cut glass, stained glass, marquetry, parquetry, wrought iron, nonhygroscopic bamboo, pictures of wood on termite barf, etc., if fashion changes or your customer è mobile (as in the aria from Verde's Rigoletto). St. Roy might quip, "The Three Tenons" http://www.youtube.com/watch?v=vY0YYLDDP1U
I can tell for a fact from long experience PL 400 will stick slate down to a plywood or OSB subfloor PERMANENTLY. About thirty years ago I was a builder. I wanted to install slate in a foyer and I was intimidated by the grouting process. I live in VA and we are fortunate to have the slate quarries in Buckingham County. Some of the finest slate in the world comes from there. I bought some that was called pattern A-10 Butt Cut. The butt cut part meant the pieces were full sized and were not to be grouted. The problem was that the pieces were not perfectly sized and I spent a lot of time fiddling with them to eliminate the gaps. Then how to glue them with out destroying the nicely fitted pattern? Lift each piece out, put a circle of PL 400 on the back and drop it back into place. Then, "walk it down". Walk on it, leveling it and sliding the joints ever tighter. Many years later the owner called me. wanting to remove it. He tried everything we could think of. Poured lacquer thinner on it and let it stand until he thought he might pass out. Nope. Heated it with a torch until the slate was exploding. Nope. Tried getting under it with a chisel. Nope. Finally tore out the plywood and all and set it in the woods behind his house and eventually the plywood rotted.
I have it in my hall, on my steps, and on a landing. About thirty years. Not one of them is loose.
I have a friend who buys "stuff" at freight auctions. Most of it has some sort of damage. He got a patio table that was a grid top with tiles in it, many of which were broken. Went to Home Depot and bought 18 cheap tiles about a foot square and they fit perfectly. About $15 "fixed" the table. I do wonder about turning the table over as William points out.
I like the grid idea, especially for an out door table. The idea of a solid sub-straight seems to introduce lots of potential problems. Rot for one. Even if you used cement board, water might get under it and freeze.
I think you are referring to a latex additive: on a table I don't think it matters, but it does make clean up somewhat more difficult. I just used straight mortar.
