Glueing Teak
Larry
What is a good glue for glueing teak ? The Teak is off a old sail boat that wasn't kept up. The old glue joints let go, and the Teak seems to be dry ( On oil in it).
Thanks
Glueing Teak
Larry
Thanks
Re: Glueing Teak
a. EPOXY
b. Resorcinol [sp] as in 2-part marine adhesive
Re: Glueing Teak
Lee Schierer in McKean, PA
I think Norm always used paint thinner or lacquer thinner to remove any surface oils before gluing. I don't recall what glue he used.
Lee
True, But
If the wood is weathered and dry, solvent shouldn't be needed. If resurfaced to fresh (oily) wood, lacquer thinner is preferred as MS takes too long to evaporate.
As much as I hate to recommend it...
Don Orr
...polyurethane glue works well on this type of wood. Probably not as strong as others though.
Could you be more specific?
Keith Newton
Are you removing a part, and putting it back?
What part might that be? There are so many answers that might be good for one situation, but not for this.
Re: Could you be more specific?
Larry
Yes, I'm removing the part and putting back. The part is a little cover.
Re: Glueing Teak
Jesper, Denmark
If you de-oil it with thinner or acetone, you can glue it with any woodglue you would have used on other wopod species.
On boats, Weldwood is often used. Long open time and slow (24 hr.) cure, but very strong and UV/salt water resistant.
West Epoxy System *LINK*
Jerry Gibbs
The West epoxy people have an extensive online manual for using epoxy in all applications. Here is a gluing guide that includes teak.
epoxy/teak
Keith Newton
Dang, Larry, are you trying to make it vague? Is this something you can clamp? Does the joint fit back together perfectly? Is it caulked into the deck, or is maybe hinged to something bonded to the deck? All of these are important.
Is it a miter joint, butt joint, M&T, or just edge glued?
Probably the answer will be epoxy, maybe thickened if it needs to fill a sloppy fit. it doesn't need a lot of clamp pressure, while the other ones do.
If it needs to move, it may need to be some sort of flexible adhesive, from a caulking tube. Beyond this, I'm incapable of helping by guessing what your needs are, is you are incapable of describing it more than one short sentence.
If you can get your hands on a West Marine catalog, there are good help pages in each section laying out good suggestions for each situation.
solvent pretreatment
Has anyone tested this treatment and shown it to be beneficial? I tired gluing IPE and washed the surfaces with acetone. Lots of yellow stuff dissolved and the glue joint still failed when I tested it.
I get the theory, the solvent will dissolve the oils that prevent water based glue from wetting the wood surface. But in practice, the solvent is going to penetrate the wood and bring additional oils to the surface as it evaporates. I can imagine that an extensive extraction would be essential to leave the surface to be glued oil-free.
Lee Valley sells an exceptionally stinky epoxy that glued IPE successfully.
Re: solvent pretreatment
craigd
Most of the "experts" (ie books, well respected authors) I've read say it is a bad idea to use a solvent: yes, it removes the oils but the solvent also dissolves the oils a little further in and they migrate to the surface quickly, leaving the problem as bad or worse.
Instead, the suggestion was to lightly sand (or plane?) the surface just before gluing to remove the surface oil and not give the deeper oils time to migrate out to the glue surface.
That is exactly what I thought would happen, yet I have seen this solvent recommendation many times repeated. Always wondered though if its advocates ever tested the theory that it works.
William Duffield
Some rigorous, controlled tests, with numerical results from a hydraulic jack with pressure transducers (beyond dropping an anvil onto the joint) would be preferred to anecdotal evidence. OTOH, I suspect that at least some of these "experts" have actually experienced teak glue joint failures, and probably experienced fewer of them after adopting the "insurance" of cleaning the joint with acetone. Most of us woodworkers, even if we have a bottle jack in our shop, don't have the requisite measuring equipment.
These guys are real experts: They formulate, test and sell a highly respected line of epoxy products, and also build high performance racing yachts. http://www.westsystem.com/ss/surface-preparation/
When setting up the teak test, It would be useful to also test another gluing methodology, which should not have the adhesion problem: Prepare the surface with a toothing plane and glue with epoxy. Use of a toothing plane (to give the surfaces some "tooth") is a technique that has been used for hundreds of years to attach veneers to a wooden substrate, but using hot hide glue instead of epoxy.
On a related subject, this month a CJWA member brought some caramelized* tulip poplar cutoffs to the meeting to be given away. It looks a lot like steamed walnut, which I guess is an advantage. He noted that one should use Gorilla (polyurethane) Glue on them, as TiteBond doesn't work? Why?
*torrefaction http://en.wikipedia.org/wiki/Torrefaction
glue testing is trivial
The metric on glue efficacy is wood failure. Testing is trivial. Make a lap joint. Cure glue. Bash it apart with a tensile force. (I put one leg of the lap joint in a vice and bash the other leg with a hammer). Estimate wood failure. I got zero after an acetone wash and Titebond on IPE.
I believe this solvent wash to be a myth that advocates have never tested. It sounds good until examined in more detail. Solvent is going to wick oil to the surface .
toothing plane and adhesive mechanisms
A microscopic examination of wood reveals it to have plenty of structure for glue to penetrate, presuming the glue wets the surface. This is not my assumption but rather a statement made by an adhesives expert at Virginia Tech in response to a question I posed on what was the mechanism of adhesion of glue to wood. The answer was "indeterminate" for the mechanical lock provided by the wood pores confounds the determination of which mechanism is most important.
Recall we had this toothing plane discussion on the Hand Tool Side some time ago and it was agreed that the toothing plane was not invented to roughen the wood. Rather it was invented to prevent the destruction of figured veneer while planing it.
Re: toothing plane and adhesive mechanisms
I'm curious who was involved in the discussion and how this conclusion was reached, as my memory fails me. I suspect that the discussion involved the preparation of show surfaces in woods that were highly subject to tearout. The preparation of joined surfaces, especially for the application of sawn veneer to a secondary wood surface, is a horse of a different feather. Historical, physical evidence of the widespread use of this technique is irrefutable, and is supported by current practitioners of these traditional methods. Further, the toothing plane was applied to both the non-show surface of the veneer and the much more well behaved surface of the subtrate wood.
Re: glue testing is trivial
When you say "zero," do you mean that the failure was completely at the glue joint and none within the wood itself (which I think implies the glue bond was obviously weaker than the wood)? This would be a significant result, and a substantial departure from the "common knowledge" that most glues used on wood are stronger than the wood itself, and that any subsequent failure would not be expected to occur at the glue joint.
Practically, many of the failures I've seen have been partially at the glue joint and partially within one or the other bodies of wood on either side of the joint. I have to wonder how the academic researchers structured the tests they report.
GolfSteve in Calgary
I've very limited experience here, but I've had one glue failure on an east-indian rosewood to spanish cedar lamination, which I think was because I didn't either sand the surface or wash it with acetone immediately prior to glue-up, and I took the lamination out of clamps a bit too early and the rosewood curled and peeled off due to moisture still left in the joint. This was a multi-layer lamination of veneers, so there was a lot of glue/moisture over a large surface area.
I do "believe" an acetone wash works, but also believe you have to wash and wipe the surface until all trace of oil residue disappears. This can take quite a while - several minutes of wiping with acetone until your rag shows no sign of discoloration. Then immediately glue-up before any oil can seep to the surface.
I say "believe" because I've never tested it. I've glued rosewood successfully with both freshly sanded or planed surfaces, and with surfaces that have been acetone washed until residue free. I usually use Titebond Original or Fish Glue.
