Now why did it take so long to think of this?
John in NM
Work holding makes rasp work sooooo much faster, only took me a year or so to think of this!
Re: Now why did it take so long to think of this?
Ralph Lipeles
As an old time car enthusiast I'm curious. How does the ball joint fork fit into your project?
Ralph Lipeles
William Duffield
Yup. Reproduction furniture makers often use that setup for carving claw and ball feet. You shoulda asked over on the Hand Tool Forum.
Here are instructions for building a wooden one.
http://www.closegrain.com/2011/05/building-al-breed-carving-vise-and-bow.html
There is also a commercial version available that mounts in a dog hole in the bench top. It is most often called a gunstock vise. While it is a bit too short for most cabriolet legs, it would hold whatever that thing is you are carving perfectly :D .
http://www.woodcraft.com/product/2003516/25437/woodriver-patternmakers-or-gunstock-carving-vise.aspx
If you have a patternmaker's vise like the Emmert to hold your bar clamp, you get even more flexibility in movement and work height.
The fork
John in NM
I was using that to remove a drive spur from a duplicating machine. I need to make a more solid set up than those spurs, but to do so I needed to know how big a hole was required to mount to the rest of the machine.
Probably should put stuff away more often :D
