I have had a hot glue gun for years but very seldom use it. I read the glue was some sort of wax and dismissed it as being not very good. Probably I was wrong.
Lately I used it like caulk under some rattling drawer bottoms while repairing some kitchen cabinets.
Does anyone use hot glue? What for? Any particular type or brand?
As a turner I use it a lot for holding work to faceplates, especially if the work needs to be removed and repositioned.
My heat gun will produce nice little round balls place in frame and panel doors to keep the door from rattling. When it's heating up it sits upright on my workbench. It drops a nice little ball on the bench and usually if I'm doing something else will make a nice little stack of balls. I was looking in a magazine one day and saw the little spheres that someone is selling to put in frame and panel doors and I thought, you know if I just move the gun every time it drops a ball I'll get a bunch of them to use later for that purpose. So now my workbench looks like it has clear rabbit turds all over everytime I heat up the gun.
Also, as a turner I use it for holding workpieces to wooden waste-blocks. The strength of the bond is very high. I end up having to turn the waste-block off or I could heat the piece but I don't.
The one thing you have to be aware of is the 2 types of hot-glue. The clear sticks, usually referred to as hobby or crafting, is considerably weaker than the heavy-duty yellow colored glue.
If you are gluing massive objects which will act as a heatsink or large areas, pre-heating the joint area with a heatgun or hair dryer will help keep the glue liquid longer.
There are hobby hot glue applications, then there are industrial. I use a 3M jet melt gun at work every week. Temps close to 300 degrees. It gets used to bond wood, rigid urethane foam, cardboard, etc..... Excellent hold, but this stuff will take your skin off. If I get any on my fingers, it has to stay or if I try to peel it off, the skin will come with it.
You picked one of my favorites: holding drawer bottoms in their grooves. As for the glue composition, it is available at the industrial level in dozens of different formulations designed for strength, rapid drying, transparency, material suitability, etc., as well as different stick diameters and lengths. Similarly, glue guns are available in many wattages to melt the adhesive at different rates depending on the application.
At the hobby and small shop level, there aren't too many options, but if you're willing to buy a $175 gun and a 20 lb box of 10" sticks, you have a real smorgasboard of possibilities.
Before my shop burned down, I had a mid-range Bostitch gun that would crank out a 10" glue stick as fast as I could pull the trigger. I used it for production work, gluing fillets into glass panel frames. It was a lot easier than trying to do it with a pin nailer or screws. I made sure to use a formulation that stuck to glass.
When I have to reproduce a broken part of a piece of furniture that stuff is perfect for putting the broken pieces back together to get the shape right. I use it around the shop all the time. Handy tool.---Jack
Another use I did for my moving around the house after my shower...take a large towel
(big enough to go around your waist) fold over one side about two inches, then hot glue it to the towel making a loop the entire length. Then take a wash cloth and hot glue it to the front of the towel for carrying around your items(large pocket it makes). Then take a cloths line and loop it thru the waist loop
making a sort-of belt to tie off. Works fine for me.
Use of Ethelene Vinyl Acetate (hot melt glue) in the repair and restoration of carved wooden art objects is elucidated in the latest blog post at Don's Barn, which also references his article I posted above.
