Tile-top table construction?
Henry W
My current project is to create a tile top table, a square top that is 30" on a side. The tile p[attern itslef is a total of 25 1/2" wide, so the oak banding or frame will be 2 1/4" width with mitered corners.
I have an over-sized 3/4" birch plywood substrate for the tile.
Option A: Size the plywood to the tile pattern (25.5" square) and attach the oak frame to the plywood (pocket screws underneath? splines?)
Option B: Size the plywood substrate larger than the tile pattern (say a square 28" on a side) and then surround that plywood and tile "picture" with an oak frame of an appropriate profile to cover all the edges? If option B, how would you attach the frame to the plywood?
A related question - it seems like gluing/screwing the oak frame to the plywood may be asking for wood movement issues, but I am not so sure it will. If the plywood doesn't move with humidity, and the inside edge of the frame does not move, isn't all the movement constrained to the outer edges of the oak frame?
Thanks in advance.
Henry
Re: Tile-top table construction?
B
Cut a rabbit on your oak to fit the ledge and flush up to the edges of the tile and the ply. That will give you mondo glue surface so other fixings won't be needed. I'd go so far as to prefinish the oak, then tape it, attach it, grout your tile, and last, remove the tape.
BTDT with Walnut and Emperadore Marble tile. Still going strong today.
Re: B - Thanks Mark
Re: B - Choices
It all depends on your edge profile. You can rabbit both the banding and the ply if you need more wood for the top edge profile.
Another thought, if you're using ceramic tile, consider using epoxy grout. You won't be hassled later with tiles lifting because water got in the cracks. Grout the joints full then, before the epoxy sets, clean the tile with denatured alcohol.
Option C
Make plywood one tile grout joint bigger than tile field. Miter and spline "picture frame" banding to plywood. Lay tile. Tile should be slightly higher than frame so anything sliding around on the tile doesn't abrade the wood frame. Fill joints with grout. To clarify, starting at the edge you have the wood frame, a grouted joint, then tile.
I have done several tables this way however I can't find a picture of a mitered frame and tile so picture 1 shows a mitered frame and picture 2 shows tile in a frame and leg arrangement.
Re: B - Choices
I think to look right there needs to be a grouted joint between tile and wood frame, ie. each tile is surrounded by grout on all 4 sides.
Agreed
Henry W
Bill - I had planned to have a grout line between the frame and the tile. I had not thought of having the tile 1/32 - 1/16" higher than the wood frame, but now that you raise it (pun intended), that sounds like a great plan.
Thanks for the input.
Henry
Thought
that's what I put in the drawing . . .
don stephan
2 1/4" sounds wide for the banding - the miters may want to open up winter/summer.
Re: Agreed
If the edge of the tile has a radius attempt to make the wood the same height as the flat part of the tile edge and leave the curved part of the tile edge proud. This is not a precise thing to do because one has to account for the tile adhesive thickness.
Joseph Mulherin, sr
I agree with Bill and Mark....raise the tile above the wood edge by placing
some bailing wire strips under the tile, grout the edges then install the tile
with the epoxy grout and space with thin spacers.
I did this on a chess table and it worked out nice.
Kneale Brownson
Note
Kneale Brownson
Everyone I've ever talked to about tiling suggested no grout where materials differ/surfaces change. Something flexible like silicone caulking.
Good Point
especially where the grout material and both sides are "captured" but subject to shape changes. With a table edge, the wood can expand and contract on the outside so extremely small movement (if any) against the grout in this application. Plus epoxy grout is not rigid as hard-set cement grout. I've done it with stone, wood, and porcelain tile and the joints remain solid and tight after years of use. I wouldn't use hard-set in this application because vibration on the table will crack cement grout and it'll chip and crumble over time.
data to the contrary
I have tile grouted with whatever comes in the bag next to wood on many objects. Never knew it was suppose to not work so I never had any reluctance to do it. Some of these things are 20+ years old. None have cracked grout.
A frame is long grain and long grain doesn't expand/shrink significantly.
As the ad says
"your mileage may vary . ."
I've done porcelain tile counters with both bull-nosing and wood edging. The wood-edged counters done with hard-set all had to be regrouted after several years. The epoxy-grouted counters were bullet-proof for both durability and stain resistance.
Re: As the ad says
Tony - Memphis
I's like to try that type of grout - next time. I built a tile top table for our patio. I used cement board as the substrate and used "normal" tile adhesive and grout right off the shelf at Lowes or HD. I added an aluminum strip around the edges to frame the tile. The tile top rests in a rabbet in the table. I treated the whole top with a stone treatment material I found at Lowes or HD - the tile is tumbled marble. Anyway, I've been very pleased with how well it has held up, but there are small cracks where the grout has pulled away from the aluminum edge. No biggy- the cracks are hairline type, but I might try the epoxy grout next time. I got this tile (actually a border strip) for a buck a strip, so I was really just playing around. I understand that grout ain't what it used to be...which is good.
Tony
Really Depends on Use
Lightly/gently used surfaces are likely to do just fine with cement grout. Tops that need to take abuse (counters and tables where stuff gets spilled) are a different matter. Bill's pictured table holding his grill would likely best be done with cement grout so as to withstand the grill's high heat.
PS: Nice little side table.
Thanks all - very helpful!
