Painting MDF
james runchey
I have a small project in mind using MDF which I would like to paint a gloss black.
Would this take a decent paint job, or should I use something else?
Painting MDF
james runchey
Re: Painting MDF
It's a sponge. You need to seal it first.
There is a commercial product known as "glu-siz" (or close) that you can apply.
You can, however, make your own with plain old PVA (Elmer's etc.). Thin it out by half and brush it on, allow to dry, repeat. You can also add pigment to match your final paint color. Usually take 2 or 3 coats. Spray or brush. When dry you can lightly sand out any brush strokes to get a smooth paint finish with your top coat.
Re: Painting MDF
Dick Coers
No other materials will work as well as mdf for painting, but it's still not easy for high quality gloss paint.The end grain is a sponge, the skin is not. The quality of the primer will determine how well the paint job goes. As mentioned, you will need to glue size, or putty fill the end grain, before multiple coats of primer. Unless you use something like M L Campbells Clawlock which really builds quickly. The last high gloss I did on mdf showed a ripple in the face skin on the MDF. I did not block sand the face because I thought it was smooth. It was smooth to the touch but not to the eye. It had enough imperfection on it to show through the gloss black lacquer. Customer accepted it. I would suggest gloss black Formica as a much easier method than paint.
PS
If you're looking for a glass smooth top, you'd do well to apply light sizing (glue to water 1:4), allow to dry that sand carefully. Probably take a couple of applications. Wear a mask as it powers badly.
Further note: MDF, while heavy, is not terrible "structural" so an unsupported top will sag. Don't leave it unsupported at more that 16" intervals and expect it to stay flat. In a gloss black top you'll see any dish or bump.
You might also consider MDO which is plywood with an MDF layer. You'd then need to edge band the ply. I have had MDF that was less than uniform in its density. Glue siz would not cure that on the edges but epoxy does a good job of filling it.
Re: Painting MDF
Keith Newton
James, There are different grades of MDF, some of which is a lot harder and finer edged, even some for outdoor projects. See if you can find the wholesale supplier for the best stuff.
Otherwise, you can get some high-build epoxy primer that some of the shops use when going for that kind of finish.
Re: Painting MDF
don stephan
A suggestion I read several years ago was to skim the surface and edges with drywall joint compound. I've been using the powder or setting type easy sand version. I block sand the MDF, skim, after thoroughly cured skim again, then lightly block sand, then paint. Gloss black may be the worst for showing defects, scratches, and so on.
