***SURVEY: THE IDES OF NOVEMBER***
This month's survey question comes from Charlie Belden, who posts mostly on the turning board. It goes to the essence of creativity and the way we approach our woodworking profession or pastime. I'll let Charlie speak for himself here. Your replies will be collected and distilled for our next News & Views column in Woodworker West magazine. Thanks for participating!
Ellis Walentine, Host
"We tend to stick with the familiar, doing things we know how to do. Conversely, we tend to shy away from the unfamiliar and resist trying things that seems to have a steep learning curve. "Small steps in the direction towards where you think you want to go may get you there. And you may end up there eventually. You'll also know more about the path you've taken probably better than anyone else on the planet. Incremental refinements to an idea can result in finer and finer pieces. That's definiitely a good thing. "Practice makes perfect" is true - unless - you're practicing the wrong thing, bad proportions, bad techniques, bad finishing methods, . . . "But when you step away from the familiar and start trying things you dont know how to do - yet - things can get quite interesting. You may find that the Steep Learning Curve you thought was there, may not be all that steep. or not steep at all. "Jack Of All Trades, Master Of None - or - Master Of One - or - somewhere between the two? Where do you fall on that continuum and how do you see your turning or woodworking journey? "I tend to lean towards the Jack of All Trades --but that could just be a matter of a short attention span and a curiosity that gets me going in a lot of different directions - sometimes at the same time."
