Heat? damage to Formica Question.
During the remodeling of my rental house I glued a piece of Plastic Laminate (Formica, I think) to the wall behind the kitchen cabinets and range. (I thought this was really clever and showed great foresight.) Two years later the tenant moved out and we have to turn it around again. The plastic laminate behind the range is odd looking. It was Almond color (off white) and now it is two different colors. Part of it is still Almond but some of it appears to be white. Apparently they cooked a LOT of fried stuff. Is this stuff heat sensitive? Any thoughts?
(Who knew such squalor still existed in America?)
Re: Heat? damage to Formica Question.
waroland
All laminate material whether Formica brand or some other are damaged by heat.
I know heat will damage it. I've seen plenty of it scorched by hot pans and various fryers or whatever that lost their heat shields.
This does not appear burned, it appears bleached. ?
Dick Coers
Formica is craft paper saturated with resin. Yup, heat can change it fast!
Are we saying putting it behind a range is never a good idea? Will it be damaged by even a normally careful cook?
Richard McComas
HPL is flammable, stainless steel isn't.
Whew... Better than I expected....
I started cleaning the Formica today. The results are better than I expected or actually pretty much what I expected when I installed it. Turns out it had several layers and types of smutz on it. This is in a rental house and I put it there hiking it would be easy to clean, both for them and me. There are layers of stuff of substantial thickness on it and mixed into that some smoke. Apparently they had a kitchen fire or burned the heck out of something. I am glad it was there. I love it when a plan comes together.
William Duffield
Many years ago, my MIL had a stove top fire. The wall behind the stove, between the stove and the hood, is Formica. It scorched. Instead of recovering the wall after the fire, she glued some ceramic tiles over the scorched area (5 of them, each 8" square, because that's what it took to cover the damaged area). They're still there. If I had the wall to do over, I would definitely tile it again, both for the fire protection, and because it is as easy to clean as, if not easier than, the Formica.
William, This is kinda funny....
As long as I can remember I have been into fixing and making things. I'm 64 and close to fifty years ago I went to visit my Aunt and Uncle. I must have been about 16. I knew they wanted me to fix some things so I built a walnut tool box that looked like a brief case. Fitted everything in there as tightly as I could, including a drill and and jigsaw. It weighed about sixty pounds. Practiced carrying it onto the plane and putting it into the overhead rack without letting it look "heavy". This was long before the stuff you have to go through now to get on a plane. Today they would have a heart attack.
One of the things I fixed was her counter tops. She had scorched them in two places with some sort of fryer that put too much heat out the bottom. We bought some decorative tiles and I let them into the counter top and sealed around them. As I recall, it was quite a chore without a router. She liked them so well she had me do a few more at random in other places. I wonder how long they lasted? I will have to ask.
I have done tile back splashes in other houses. Did not fit the budget on this one. Although, tile is so cheap now I might.
Re: William, This is kinda funny....
William Duffield
That's a good idea. I've done trivets with tiles inset into a wooden frame, but I think if faced with a damaged countertop, my first thought would be to excavate and inset a butcher block chopping board.
