Using Peroxide to clean/lighten wood?
I refinished my dining room floor. there was a spot that was darkened by being wet under a potted plant. Tried 3% peroxide and it seemed to help a little. In reading about peroxide I found references to 35% type. I was wondering if it would do a better job? Anybody tried it? Where can I buy it?
Re: Using Peroxide to clean/lighten wood?
It all depends on the stain.
A metal stain is better treated by oxalic acid or some sort of chelating agent. Other stains can be treated with hydrogen peroxide.
Where to get it - possibly Woodcraft. You'll have to look for it.
I've got about 5 gallons of 35% food grade that I saved back from a project.
William Duffield
As JL suggests, try some Bar Keeper's Friend (or maybe Zud, that at least used to have oxalic acid in it (read the label)) first. I shake it out on the floor, dampen it slightly and scrub with a ScotchBrite (or Norton BearTex) pad.
One part of the two part wood bleach that Woodcraft carries is peroxide. I always keep a quart of H2O2 in my cupboard, just in case the bench dog has an encounter with a skunk.
Howard Norman
Thirty five percent hydrogen peroxide will be avai9lable from an industrial chemical supplier. The minimum quantity will be one gallon if they will sell that small amount of it.
Where to buy it?
Gary Smyth
Gee, just type in 35% Hydrogen Peroxide on any browser and make your choice.
I was considering.....
using it to clean the inside of cabinets. I have no idea what manner of squalor they left under the sink or in another cabinet. Both were new when they moved into the house two years ago.
I built them and finished the interiors with lacquer. Maybe I should use oil based urethane or solid stainless steel about an inch thick.
Duh! Us old fuddy duddies keep forgetting...
about the Google. Thanks
Wet under a plant sounds like mold stain to me. Chlorine bleach is excellent for mold bleaching. Never tried it on an oak floor but its worth a shot.
35% peroxide is a powerful oxidant. Used or handled in the wrong way can lead to an explosion. "Don't try this at home" is often used in the same sentence as 35% peroxide.
Bill....
I may have made yet another mistake. I was thinking of Pee stains. I have seen dozens of oak floors damaged by pee. Have been told it was very difficult to remove. It never occurred to me that the similar looking black stain left by potted plants would be different and easier to remove. We did not try very hard on the floor because I thought it was impossible. The 3% solution we dabbled with for a few minutes Seemed to help a little bit and remove some of the dappling.
Now I am wondering if we could have done more with???? What would you try?
Barry, I'm not so sure I would
Keith Newton
Use the strong stuff under the sink, unless you are wearing super has-mat protection. I sure wouldn't want to be breathing any of that in a confined space.
Re: Where to buy it?
Ralph Lipeles
Women use peroxide to bleach hair. It should be available at places that sell beauty supplies.
Ralph Lipeles
no harmful fumes from peroxide
It may generate something toxic from what ever it is bleaching but the peroxide itself yields just oxygen and water, and if it contacts the wrong stuff a lot of heat, as in boom.
Not sure what product I used about25 years ago
Keith Newton
But doing something similar, i thought I could hold my breath, and go in for short working burst, but ended up with a cough that lasted about a year.
Bill, you don't think scrubbing with a brush, sending vapor into the air, breathed into lungs would cause a problem?
