A different thickness planer Question
My Dewalt 733 thickness planer has a problem. As you pass stock through it, it make a noise, sort of like a cough, the work piece seems to stop for an instant, and then moves on. I have started pulling on the piece to help it along.
Does anyone have a clue? Is it gear drive and one of the gears may be dinged? Is it belt drive and the belt slips? Is it a toothed belt?
I have some stuff to make between now and Christmas and don't have the time to tear it apart and order parts. I assume the internals are similar to the 735 mentioned below. Mine is the version that used the reusable knives. I have sharpened them several times and I have a spare set. (99% sure this is not a knife problem)
Any suggestions what to look at first?
Re: A different thickness planer Question
It's a sprocket and chain drive. One or more sprockets have lost teeth, or even split in two. It's really easy to fix. You can get replacement gears from ereplacementparts.com.
http://www.ereplacementparts.com/sprocket-p-68042.html
Take it apart and find out how many you need to replace before you go and order too few.
Stuart Johnson
I'm interested in this thread. I've got the same 733 and also have the problem. The main issue mentioned in the past is dirty rollers. I've clean mine very well with no change. I use a wide belt sander for final thickness so the marks from the slippage aren't important but they are annoying.
I'm fairly certain the problem comes from the drive and will tear it down someday but it seems like whenever I get that far into maintenance I end up with a few pieces left over when I reassemble it.
I have a service bulletin showing the part numbers and diagram. If you need a copy I'll scan it and send it to you.
William Duffield
I looked up the info I have from when I repaired mine about 4 years ago. In addition to more than one broken sprocket, I also replace both chains, based on the theory that worn, stretched chains had probably been the cause of the broken sprockets.
Tearing it down, replacing the broken parts, and putting it back together was not difficult.
It still runs fine after the overhaul, but I learned the hard way not to try to run 10' long 8x8 old growth southern yellow pine through it. :\
William and Stuart.....
William, Could you look at the E-Replacement site? When I went there a sprocket and chain came up on the right hand side of the Dewalt planer section. Are these the ones I need? They were about $4 and $6. Right up my alley. Better than the feed roller at $36.
Stuart, If you would look at the same place I sent William to and tell me if your diagram is better, I would appreciate it. If it is I will send you my address or you can fax or scan it and e-mail it.
I would actually like to order the sprockets and chains and then tear it apart so it will be out of service only briefly. Either way, if it goes well I will photograph the process and send it to you.
Re: William and Stuart.....
William Duffield
I know the sprockets (Spacely?) are just a little over $4 at erepacementparts, but didn't check on the chains' prices. However, the 733 uses lots of sprockets, of at least three different types, and you don't need to replace the ones that are not broken. You don't need to replace the sprockets or chains that lift the head. Whether you will need to replace the sprockets and chains that drive the feed rollers or the sprockets and chains that drive the cutter head, you won't know for sure until you get it apart. It's been way too long since I had mine apart to remember which failed in my case.
Thanks William, I am just trying to avoid the inevitable. (Tearing it apart and waiting for parts)
Dale Lenz
Barry...
Dale Lenz
before I did anything, I'd wax the planer's bed and in/out feed tables.
Good luck
chris grothe
Barry, I have the type 1 733 and had the same problem. The cause was a worn bushing that finally broke a sprocket with the stops and starts. There are 4 bushings (2 of mine were bad, but replaced all). The blow up picture part is #57 and the order # is 285945-00 Chris
William Duffield
Anything that can go wrong, will go wrong…
You'd figure there would be one weak link, but it appears that is not the case for the 733. At least, now Barry has enough evidence to convince him that he needs to look inside before deciding what needs to be replaced.
Stuart Johnson
Their diagram is the same as mine. The .pdf can be blown up for easier reading. I've dealt with them in the past and they ship very fast.
Thanks, both of you...
Opened mine up today.
Stuart Johnson
I pulled off the cover and got to the sprockets and chains. I turned it on and watched the chains. There is a chain from the drive motor to the back roller and then second chain to the front roller. Both chains have a tight side and a loose side but the interesting thing was the chain from the drive to the back roller. From time to time the loose side would flutter. I wasn't running anything through it but it seemed to be about the same timing as the skips I get. One other thing, there was a lot of saw dust and ships packed in the chain housing. That might not have anything to do with the skipping but it can't be of any help.
Re: Opened mine up today.
Stuart, this is what I want to do. Open it up and look, but I don't want to tear it apart and put it out of commission. Can you explain what you did? What did you take off to get a look?
I printed out those diagrams, but I don't even see a chain.
Stuart Johnson
1. Remove the crank handle. 97
2. Remove four screws, 96
This allows the yellow sides and black top to lift straight up.
I've re-written this next part several times and it doesn't make sense.There is a box on the left side that covers the chains. Two small screws will allow it to be removed and the chains seen.
I'll take a few photos later. It was very simple once done but did take a bit to figure out.
