When I feed my wood through (in this case, Padauk), I get mild scoring/burnishing on the underside (the side opposite the cutter head/rollers). The marks are not always the same, varying in amount and placement. The marks are very shallow, and 1/8 to 3/16 inch wide. Any idea what could be causing this? The table of my planer is very clean, the knives are new, and the dust evacuation port is clean.
If there are chips jambed in the gap between the infeed and outfeed beds, this would be the most likely cause. Otherwise, raise the head up high, so you can get your hands in to feel for dings. Also, it is a good idea to take the bottom platen out every so often, to clean chips out from under it, which can cause uneven thickness. Wax it all and try again.
If you still don't find anything, I have to ask if the wood has been fed over any other tools, which might have scored it before going to the planer. Some cast tops can easily get dinged by falling objects or transport, along the corners. I always file a little chamfer along the top corners of my tools to prevent this.
Could it be that the marks are not in fact grooves, but rather raised ridges? If so, they are caused by nicks in the planer knives. Nicked planer knives cause an elevated ridge the length of the board which will, on subsequent passes once the board is flipped, manifest as discolored lines. This is due to the high pressure the head exerts as the piece runs through causing friction which picks up schmutz (technical term) from the planer bed.
The fix in that case is hone/ replace, or offset the planer knives as necessary.
Even if your knives aren't nicked, the board may have run through a planer with nicked knives when it was milled before you bought it.
Reading the other replies leaves me with one thought. I have a Delta portable that's similar and I think I would be looking at the bed and feeling for any scratches or bumps that may be there. This is easily remedied should it be the case. Plus it helps to keep those bottom surfaces waxed for easier feeding.
Chips on the table or on the board when you flip it side-for-side. I get that all the time. Sands right off as the marks (I get) are just lines of compressed fibers. If you situ is different, than I can't help more.
If the marks are on the "underside" they are coming from your table. I no longer use my DW733 (have a stationary now) but I used to have trouble with the material feeding unless I kept the table waxed. I also had to remove my table one time and found derbies wedged under the table (caused tapered boards). I would clean and inspect the lower "tables" and that whole area for burrs and rough areas that may be causing the problem then wax the surfaces.
