OT- dishwasher woes
OT- dishwasher woes
OT- dishwasher woes
Tom
We have a Bosch dishwasher that is about 10 years old. my wife has been noticing that the dishes do not seem to be getting very clean. Have plenty of hot water but not sure what to look at.
Suggestions?
Thanks!
Re: OT- dishwasher woes
more info ??
del schisler
just quit getting dish's clean, just happen, change soap? It take's more than hot water, well water, not soft any more, something has change, step back and look at what has change?
Dustmaker Mike
Does it have a food disposal in the bottom? If so make sure it is not plugged and is clean.
Tony - Memphis
Does it have an auto detergent dispenser?
Are the dishes not clean or just cloudy looking?
Jim Rahbe
Tom,
If the basic problem is that everything that used to be sparkling clean now seems to be cloudy, I suspect it is your Dishwasher Detergent and not the dishwasher itself. The residential detergents you can buy in the local supermarkets no longer contain phosphates and as a result leave dishes with a cloudy appearance. And just like compound interest, the effect just keeps adding to itself and gets worse over time.
I buy the older version of “Cascade” which is sold to commercial users and still has phosphates in it. If I use the residential products it takes about two weeks for the dishes to become noticeably cloudy. If I then start to use the commercial detergent it takes about two weeks for the dishes, and the inside of the dishwasher, to become crystal clear again.
Jim R.
Nat Robison
The detergent issue aside, I find that crap tends to plug the holes in the spray arms pretty regularly. I now get out the tweezers and try to clean out the holes just about every time I empty it. I typically find at least one of the holes plugged.
I've also read that it's a good idea to run a cycle with just a cup or two of vinegar in the machine to clean out soap and other deposits. I do that in mine every few months.
Good info...
John in NM
I'm going to look around for a restaurant supplier and try to find that, thanks Jim.
Out here, it takes one wash with the wrong soap to get a horrible cloudy effect. The cloudy film is so heavy you can feel it on plates and glasses.
We've been using some of those fancy little "pods" plus a couple cups of vinegar and that takes care of it. But dishes still have to be pretty much clean when they go in, which irritates me to no end. I have a dish drier more than a dish washer.
add some vinegar
Dick Coers
If you have hard water, you may have lime filling some holes. Run a cycle with lots of vinegar, no dishes. Then add about a cup of vinegar when you run the dishes. Glasses come out squeaky clean. Our new dishwasher is really sensitive to water in the machine at the start of the cycle. If we add the vinegar before the cycle starts, it pumps it out. So we let it start filling with water, then open and add the vinegar, then continue the cycle. We buy the cheapest grocery store vinegar we can find by the gallon.
Re: Good info...
paul in AZ
Our water here is very hard and not only was I getting that cloudy grit on dishes and silverware but my drain line actually plugged up with undissolved soap. I had to get the plumbing roto-rooted out a couple of times before I realized what the trouble was.
It was not grease buildup but was soggy soap plugging the line.
The soap people quietly dropped the phosphates from dish soaps and the dry soap powders do not liquify.
I now use the little 'pods' and have no more problems.
Hard water...
John in NM
That is the problem here too. The town water we get is reasonable, a bit harder than I remember from living in Tucson, but still reasonable. Even those little pods won't work without the vinegar in every wash.
Some of the local wells can run to several thousand ppm total dissolved solids, which is not considered potable even in the desert. All depends on which formation the water is coming from, the town is lucky to have wells up in the local mountains which are mostly granite.
John Veerkamp
Most dishwashers have a screen down under the spray arms. When they clog up it no longer cleans very well. You need to remove the arms and the piece under the arms to access the screen. This is a replaceable part. available from parts suppliers and Bosch dealers. Maybe even on the internet.
Re: Hard water...
paul in AZ
I used to live in Tucson. The city gets it's water from wells, having rejected the Colorado River water that is distributed around in canals. It is the largest city in the world to rely on well water. They've sucked that aquafer so dry that they now have to drill several hundred feet to get water.
The Phoenix area uses Colorado river water. The valley has numerous canals distributing it. For some reason the water is quite hard. Only an impression but it seems to me that the water here is harder than that in Tucson.
Yes, I remember CAP quite well
John in NM
They used it briefly in Tucson, but complaints of iron stains and water leaks lead them to use it for recharge instead.
Canal water will be harder than a lot of groundwater, as it's traveled hundreds of miles in an open canal, evaporating as it goes :D
Use Less
We have softened (sodium free) & neutralized well water. We have avoided such problems by cutting the amount of detergent in half which has solved several problems; no film, no spots on the glassware. Do NOT, however, wash crystal glassware in a machine.
Tom
I had my wife read all the replies and I took the screen out of the bottom of the dishwasher. Found a number of corn kernels. So we will see what the improvement will be.
Thanks all!
