Waterlox Odor
So I am trying Waterlox for the first time. So far so good. But that smell! Smells a tad mothballish (is that a word?) Anyway, does that smell go away? Will waxing help?
Thanks in advance.
T.
Waterlox Odor
Thanks in advance.
T.
It Goes
provided you don't "seal" it in with something else which will delay the deodorification situation. 'lox is not your basic "fast finish" product. Give it time to fully polymerize. Personally, I prefer to let it sit for several days.
[Psst, Tom . . wings or the tail?
Re: Waterlox Odor
Bill Howatt
I consider a lack of odor on any finish to be an indication that it is cured rather than just dry. This may not be scientific but I don't buff finishes that have an easily detectable odor.
Bill
Re: Waterlox Odor
Howard Acheson
You are absolutely correct. If it is still emitting an odor, it's still curing and is still "tender". Oil based finishes dry/cure in two steps. Initially, the thinners evaporate and the surface becomes "dry to the touch". Once the thinners have evaporated, the varnish begins mixing with oxygen and the film becomes hard and protective. This can take 3 - 8 weeks. Keep smelling. If you detect and odor let it continue to cure.
Re: Waterlox Odor
Keep in mind that if you use the Waterlox (or other typical varnish, for that matter) inside an enclosed cabinet or drawer unit, it will probably keep that musty, old-oil smell forever. I always finish drawers with shellac or lacquer for that reason.
Yes, that's a standard caviet.....
Howard Acheson
....I used to teach in my finishing classes
