Burnmaster eagle
Burnmaster eagle
Burnmaster eagle
Richard Sealy
Thanks for all the info on Wood Burning, I've decided to go with the Burnmaster but Ive read where you can adjust the voltage from 1 up 3 volts, Does anyone know how this is done, and is there a owners manual?
also want a fixed tip pen that would be a good all around pen, suggestions on what 3 tips would be a good starter set, also a shader to use in transferring text to wood, (laser printer)
Re: Burnmaster eagle
Re: help needed with Burnmaster eagle
Here is some homework
Ray - Middletown, IN
First look up the following, Julie Bender and Jean Bouick and take a look at what pyrography can be. Then look up Sue Walters and Lora Irish, they have websites with tons of information. Finally go to http://www.pyrographyonline.com/ they have forums on tools, and several tutorials to help get you started.
Ray
Re: Here is some homework
Richard Sealy
Thanks for the home work, as it turns out I found a used razertip, single pen, with 8 pens several cords and other acc. so for now Ill have a razertip
