35 pound table leaf wt reduction plan
Chris Groves
I am nearing the completion of an arts & crafts 60" round table with two 20" leaves. The table is made from curly maple and the top is 1.25" thick... The problem is the leafs with aprons weigh a robust 35 pounds. my plan is to remove some stock between the aprons by routing 2' wide strips (leaving 3/4" thickness) so the leafs can sit on the maple table slides (paxton 5 section) and still have plenty of thickness. I am hoping to remove about 8-10lbs to make the leafs more easily moved and stored under beds.
The aprons are keeping the leafs from warping... should I add a ctr stiffener similar to the 7/8 by 2.5" aprons?
thanks for any input- Chris
