Water Base Lacquer
gfriend
Can you use oil base stains when spraying water base lacquer? Getting rady to try the new EMtech 6000 lacquer.
Water Base Lacquer
gfriend
Re: Water Base Lacquer
Dick Coers
Scares me. Hopefully you are not talking about Minwax stains, but a professional quality stain. Call Target tomorrow. I'm surprised they don't have any information for application online.
gfriend
Thanks I will call tomorrow. They have a forum and in my review it appears you can use oil base with extended drying time and denatured alcohol wipe down.
Drying time is key
I have not tried the Emtech lacquer, but I've had drying problems with lacquer over stain. Regardless of which type of stain you use, allow enough time for it to dry completely.
Insurance
1. Let your stain "dry" for at least 48 hours. Oil stains need time to get the oil carrier started down the polymerization road. There's enough oxygen in the wood to complete the process.
2. Gently wipe to catch any weeping.
3. Apply a coat of fresh (mixed not more than 3 months) dewaxed shellac mixed to 1-1/2 lb. cut. This will seal in the stain and its oil carrier and eliminate any adhesion issues. It will also give you much greater visual "depth" and richness in the final coating. Allow to dry overnight so that the alcohol can fully evaporate.
4. Rub your piece with the grain with some gray (very fine) grade synthetic wool (never steel wool- it will leave particles that will rust in the top coat) and vacuum off to remove any dust nubbies.
5. Apply your Target according to directions.
A bit of further explanation on shellac.
Used as a "tie coat", dewaxed shellac provides a solid base surface. "Shellac sticks to everything and everything sticks to shellac" is an old finisher's rule. You do, however, have to be careful to use good product that's had its wax content removed. I had a conversation with Jeff Weiss, the owner of Target here in New Jersey, after I had a Target lacquer-finished piece cold check (cracks under the finish). Jeff informed me that the problem was being found not in the topcoats but rather in the shellac under-sealers. If the shellac was too old or applied too heavily, it tended to fracture over time under a waterborne finish. The solution was to use very freshly mixed dewaxed shellac (no store-bought stuff), apply not more than 2 coats of 1-1/2 - 2 pound cut [3 to 4oz dry flakes to 16oz. alcohol], and allow to harden (fully dry) well before top coating.
Here's an example - Cherry, Watco oil, Garnet shellac, and Target Lacquer (waterbase)
Next is Walnut (maple flies), Waterlox, Ultra Pale shellac, General Enduro Clear Poly
PS
For maximum clarity, I run my shellac through a coffee filter after its mixed and before I apply it. The solution comes out crystal clear.
I also try to mix only what I will use within a 3-month window and put a date on the jar so that I know when to pitch it what's left (actually apply it to my trailer's bed
) and mix a fresh batch if needed.
Walnut question
Jerry Gibbs
Mark- I have a similar piece of walnut. It is a crotch with heartwood, sapwood and a natural edge. I have been concerned that if I don't stain the heartwood, it will lighten/washout over time. Did you stain the heartwood or do you not consider this a problem. If I do stain the heartwood, how do I keep the stain off the sapwood. These are nice looking finishes. Jerry
Re: Walnut
UV is most often the culprit when it comes to color changes. For walnut I like to use Waterlox in the finishing recipe as it will block a fair amount of UV while "popping" the grain. The addition of the shellac tie coat provides a second interface surface (wood/oil/shellac/topcoat - "/" is the interface layer). This gives the final finish more depth and is more reflective, and thus may (no data) reflect more UV light away from the actual wood surface. I don't have any information on the waterborne finishes being or containing UV blockers so can't speak to that.
I tend to shy away from stains as I prefer to allow the wood's natural color to speak for itself. Pigmented stains will generally be more resistant to the color bleaching that you describe. Keeping the stain off the sapwood is simple. Apply a thin coat of shellac to the sap wood. It will resist the stain yet will be easy to remove with a rag and alcohol before you continue finishing. You can also use paste wax and then use mineral spirits on your rag to remove it, although you'll have to be careful as the MS will pull off your stain if you slip a bit over the line. In your favor here is that the line between heart and sap wood in walnut is always a bit fuzzy so don't try to get a hard-edge demarcation because it will look contrived. Keep in mind, however, that the sapwood will tend to darken with age, and this cannot be prevented as (I'm told) it's a oxidation reaction of the compounds present in the sap rather than a light-driven change. Attached is an example. One side's sapwood is much brighter than the other, and you can see the color gradation across the transition on the right side.
HTH
thanks, Mark
Jerry Gibbs
Re: Insurance
gfriend
Mark I meant to ask you when using the Target Waterbase Lacquer how much do you cut it? Your pics look great!!
Waterbornes
of whatever flavor must be strained to remove any lumps that may have formed. Standard paint strainer cones do just fine.
As far as cutting the finish goes, I've never had to do that unless I've used additives like cross linker and dye tints, the product has been sitting for a while, and the workpiece is a horizontal plane. For vertical surfaces you want a heavier liquid to help prevent runs and sags. IIRC, you can dilute Target's lacquer with water up to 15% by volume. Keep in mind that waterbornes were invented to comply with VOC regs, and are best applied by HVLP. That means running your gun parallel to the surface with a wide fan and not more than 6-7" from the wood. That way you get the most advantage of the high solids content of the material. The Target finishes I have used have very good tail solvents and their finishes flow out and melt in beautifully. The cherry piece above was rubbed out to high gloss, but the walnut table is an off-the-gun surface.
I would not thin unless you're getting orange peel. Since I've not used Target's stuff for a few years your best bet is to address your dilution question to their tech reps by phone or email/chat.
