Gunstock repair
james runchey
I'm in the process of repairing a gunstock with some very narrow tight cracks, What is the best way to get some glue in there, and what kind of glue would work the best? It's walnut BTW.
Gunstock repair
james runchey
Re: Gunstock repair
Merle
Apply the glue to one side of the crack and your shop vac to the other side to pull the glue into the crack. I was surprised how far the glue traveled using this method.
Re: Gunstock repair
BrianMonumentCO
As a practicing gunsmith, my answer to fixing cracked stocks is to spread the crack a bit, remove some material so the pieces fit together correctly, insert some runny epoxy tinted in brown and squeeze the stock together.
Epoxy is best here since there will be some gaps, and epoxy fills gaps.
If the stock is broken in the wrist, more work is required as the epoxy will not hold fully.
If the stock is broken around the magazine well, more work is also required.
Most of the work is in the area of adding a threaded rod to reinforce the stock across the break.
Whatever glue is used must be waterproof and it will most likely be visible.
Re: Gunstock repair
Ralph Lipeles
If you just have to get the glue into the ends of the cracked area I use a thin. probably .003" to .004", thick artists paint mixing spatula. Ralph lipeles
I'm going to try that
John in NM
Vacuum is amazingly useful, even the rough vacuum provided by a shop vac.... since air is far easier to move than glue, I could see this working very well - you're using atmospheric pressure to push the glue in by creating a lower pressure inside the crack.
Usually, I use a bit of paper or better yet drafting mylar to work some glue into the pried open crack. Works well enough, but not so well that I'm not interested in finding a better method.
Re: Gunstock repair More thoughts
BrianMonumentCO
One more thought on stock repair, if the crack has not been attended to soon after it happens or there has been oil, wax etc in the crack, the glue will fail.
If the stock is finished with oil, it is likely that any glue towards the surface will fail also.
Failure here means not good adhesion.
In a long standing crack such as has not been worked on for years, the old dirty wood needs to be removed.
Along these lines...
John in NM
One approach I have taken is to saw through the crack - handsaw or bandsaw as appropriate - and then fill the saw kerf with a tinted opaque epoxy (PC-11 marine epoxy and Transtint dye).
This approach is not as good as gluing, when gluing is feasible, as it is not as structurally sound as a good glue repair, and it is also more visible. Sometimes it is a good way to go though, as in the case of an old crack that is full of grime.
Transtint tends to make the epoxy a bit softer than it would otherwise be, but that downside is vastly overshadowed by the ability to color match the mix. I've used a similar but much stronger epoxy we have at work, labeled MS-907 (brand name is Miller Stephenson). The stuff is fantastically high quality epoxy, I wish I could easily get some of my own. Its basically similar to the PC-11 you can buy in the hardware store, but more of a liquid than a paste. I'm going to guess it is higher strength as well, but I've not looked it up.
Re: Gunstock repair
Dave Bair
In some instances, the vacuum method does not work. I've been able to use low-pressure compressed air to drive enough glue into cracks to have squeeze-out when the item is clamped.
Re: Gunstock repair Still more thoughts
BrianMonumentCO
When it comes to pulling the broken stock back together (major fractures, cracks and major splits), I have had good experiences with removing interior material until all the pieces the items dry fit nicely and then using a running epoxy.
I use AcraGlas from Brownells. It comes in at least two forms. I call one runny acraglas as it has the consistency of maple syrup. This form is great for fractures and cracks. The other form is of the consistency of peanut butter (without the allergies). This works well for large gaps and for bedding actions.
Epoxy does a great job of filling gaps. in most cases there is a way to create a path for excess to flow out.
This is important as it prevents the joint from complete closure. No matter how much force, compressing epoxy and glue is nearly impossible.
One other thought, epoxy can bond to anything except wax, finish and release agents. Glue has trouble bonding to glue.
