OT: Outdoor cut Christmas tree Q's
Grant in Iowa
I have been tasked at work with getting a cut Christmas tree and building a stand to erect it outdoors where it will be decorated with lights. The request is to obtain it shortly after Thanksgiving and to keep it on display until after Christmas. Figure 30 days. I think the species we will be donated is blue spruce.
Since it will be a live tree (well, up until it is cut), how does one go about watering it when it is below freezing outside? Heat tape in the water or around the water reservoir? Is it even necessary to water it given it is winter and it will be near or below freezing most of the time? I know indoor trees must be watered, but how about outdoors in sub freezing temps?
The goal is to use about a 12' tree, which may have a butt end of up to 10-12". My preliminary plan is to weld up a steel stand that can support it without guy wires. This stand would have a capped piece of steel pipe about 16" tall as its center to hold water, and four pieces of steel tubing radiating out from the pipe to create outriggers. These can then be staked as necessary to resist wind. I would drill and tap 4 holes around the top of the pipe to receive "set screws" to allow for plumbing the tree and to hold it in place. A short spike would be welded inside on the bottom to hold the butt end.
Anyone installed a live cut Christmas tree in below freezing temps? Any advice would be appreciated. I don't want to be "the guy with the dead Christmas tree".
Thanks in advance,
Grant in Iowa
Re: OT: Outdoor cut Christmas tree Q's
Bob Entwisle in NJ
No experience, just an observation.
We hang an wreath on the door and it gets no water or any other care and is still green come the middle of January.
I'm guessing that a cut tree in mostly freezing or below temps would do about the same.
Bob in NJ
Tom Dunlap
Don't worry about watering. The tree will hardly uptake any.
If you plan this for next year you could water the tree before you cut it. Do this a few weeks ahead of time.
Tom
john Veerkamp
Your biggest problem will be drying winds. No need to water but to keep it looking nice spray it with an anti-desicant. Most garden centers, nurseries. and florist shops will have something.
Howard Acheson
Why not plant the tree for future years?
Re: OT: Antidesicants - not for everything *LINK*
Bob Entwisle in NJ
a quote form the link:
"Some caution is needed when using antidesiccants. Because leaves lose water through the same pores that take in carbon dioxide for photosynthesis, antidesiccants can be toxic to plants. In addition, these products are gener­ally more hazardous to evergreens than to deciduous plants. For example, you should never apply antidesiccants to blue spruces or other plants that have a bluish waxy coating on their leaves. That waxy coating is the plant’s own natural antidesiccant; spraying an antidesiccant washes away that wax and the blueness."
Bob in NJ
http://www.finegardening.com/how-to/qa/antidesiccants.aspx
John Veerkamp
This is a cut tree not a living tree he is asking about.
