Fastening on tops-pocket screws
In a post below some questioned the use of pocket screws for the top in question and recommended some sort of table top fastening hardware. The thought was that the pocket screws led to the top splitting. I noted that there was a split only at one end of the table top and that this board appeared to have other smaller end checks. I question that the screws were the cause of the split.
I have never seen an old table top not fastened on with pocket screws. When I took the class at the Mack Headley shop, a shop steeped in Virginia furniture building tradition, we were instructed on how to locate, size and carve the pockets for fastening tops with pocket screws. Although drilled to accept a screw without pounding it through the hole, I do not recall any warning about over sizing the hole beyond what was necessary to get the screw to drop through.
What are other's experiences with pocket screws? I have been using then without concern since the Headley class. Are there precautions inherent in using them that were practiced by Period craftsmen that we need to know about?
