Refinishing Wood floor questions
I have some Bruce 2 1/4" In a room about twelve by fourteen. It is the prefinished variety and about twenty years old. It has the grooves that appear to be about an eighth inch wide and a 1/16" deep. Its stained sort of cherry color. I need to refinish it. The finish was crap and wore off within a few months in traffic areas.
If I sand it I figure I have to sand off enough to get rid of the grooves. Right???? The question is, if I do that do I have to stain it again? I would rather not, but I suspect there will be enough stain left exposed in the crack that it would look bad unless stained again.
Re: Refinishing Wood floor questions
Mark,
I am afraid I have let this floor go way too far. There are areas where the finish is completely gone.
How would you clean the grooves?
I am assuming you mean "No you Don't" have to sand the grooves away.
Re: Mark,
Tom
On a job years ago the flooring contractor had a few guys using "V" blocks with sandpaper to snd the groves. It actually went very fast.
