stupid mistake of the week
Jerry Gibbs
I could not get electricity to the last receptacle on the line. Tried for several hours to solve the problem. Turns out I sheet rocked over a receptacle box and there was indeed an open.
Jerry Gibbs
Re: stupid mistake of the week
If you're not making mistakes, you're not getting work done.
I recently spent an hour trying to figure out where I'd managed to drive a screw into or otherwise damage the wiring in our remodel, because I was getting continuity between neutral and equipment ground lines, before remembering that I'd gone ahead and tied the wires into the circuit (capping off the hot and neutral pigtails in each box!), and, thus, the neutral and ground are connected...back at the main panel, where they're supposed to be connected.
Better than sheetrocking the cat in.
Joseph Mulherin, sr
When ever I attempt to do some work, I first sit down , analyze the problem, then make myself a check list of the means to get the job done correctly. This also applies to my construction background when I did this as a Foreman on many large projects. Made schematics of the work for the guys to follow, ordered all materials to get the job ready, then just gave them the scheds and let them go at it. Not many mistakes that way.
Kevin French
That will always give you headaches trying to figure out what is wrong. Mine was opening up the wrong side of the window to find a wire I buried for an outlet in a finished wall. SWMBO failed fully appreciate the humor in it.
You didn't happen to work on my house?
Neal in San Jose
In my new house there are two switches that apparently don't do anything. Ive asked the builder to come over and show me what they control, but he is dragging his feet. I suspect he knows someone made a mistake and he's on the hook for the correction.
Re: You didn't happen to work on my house?
Where are the switches? Let me take a whack at it.....
One better...
Jason Roehl in Lafayette, IN
I swapped out a few old receptacles for a customer, and I accidentally tripped the breaker for that circuit (yes, I was doing it live). Before I reset it, I was using a voltmeter to see if I had a problem, and I was getting continuity from hot to neutral. Not good, says I, so after some hair pulling, I finally remember that there is also a bath fan on the circuit, and the switch was upside down, so it looked off, when it was actually on, thus giving me the continuity from hot to neutral through the motor windings.
Jason
Neal in San Jose
Thanks for the offer, but the builder needs to make good. I'm guessing some drywall work and painting will be required. They are both in the dining room in two seperate boxes. My guess is that one was intended to control an outlet. I dunno about the other one.
don stephan
Friend of mine built a house this summer and paid a drywall crew very well to hang and finish. They covered two or three boxes and apparently didn't even notice the bulges while finishing. Painter found one and then Drew looked closely at every wall and found one or two more. Of course, the drywall crew promised multiple times to come out and fix the now protruding screws, but never did.
If you haven't.....
Look at the switch handles and see if they are labeled "OFF" and "ON". If not, they are three way switches and they may be to an outlet. Check ALL the outlets. Both halves of each. Sometimes they only switch one half and the other one is live all the time. Just guessing.
(When You said there were two, I was thinking one of them would be at the front door. Locally its called a "drop for a yard light". Builders install a switch to a wire under the house in case the owner wants a yard light in the future. The other one might be in the kitchen installed for a disposer. If there is no disposer, the switch does nothing. Sometimes they put the switch tot he dishwasher so they can pretend they meant to do it.)
Really professional workmanship demands they line up the all the screw slots in the cover plates, IE all vertical or all horizontal. Some electricians mark the switched outlet by setting that screw in the alternate position.
BrianMonumentCO
If the floor is unfinished, it would seem that that would be a good place to mark that an outlet is there.
Since most outlets are at a standard height you only need to know where left-right it is located.
Drywall would go up before good flooring and carpet so it wouldn't be covered until later.
Doesn't help much for retrofits.
This is where a bunch of digital photo's would pay off. You could stretch a tape across the wall and photograph it. Or take a photo and write down the left to right dimensions.
