Drill press Add-On Laser
Ralph Lipeles
I was thinking about adding a laser sighting accessory to my Delta floor model drill press. Has anyone out there done it? Any opinions pro or con?
Thanks,
Ralph Lipeles
Re: Drill press Add-On Laser
Dick Coers
Most lasers I've seen throw such a wide line, I thought it would still just get you in the ballpark. If I need accuracy, I use a center punch.
Ditto
Pencil point on wood, +/- punch. Punch on all hard materials is required. Laser is a waste of $ IMHO
BrianMonumentCO
In metal working as a gunsmith we use a center drill to help prevent bit walking.
And a good measurement with good scribed lines is a great way to line up a center drill.
We gunsmiths are lucky that we often use a mill to drill holes.
A mill has a table that can be moved in 3 dimensions.
This good because we can clamp the work to the table,
make measurements and adjust the table until the bit is directly over the hole.
Then we use the center drill and finish up with a jobber bit or sometimes a short bit.
So I don't consider a laser to be necessary as it is proximity not exactness
Bill Tindall
Iwill sell you one cheap. one came with my machine and I never use it
A.J. Hamler
A.J. Hamler
As others have noted, they're OK for quick-and-dirty drilling in the general area, but they aren't very precise.
Also, aftermarket ones tend not to hold their settings; you may spend as much time constantly calibrating it as you do using it. Drill presses that come with them built in are more reliable in this regard, but they're still proximity only.
Finally, the brighter your shop is, the harder they are to see.
Still, they are cool...
