Somewhat OT - cleaning a deck
I've an older painted deck. It really needs repainting.
I've tried pressure washing and bleach - to no avail.
My first thought is belt sander w/ a coarse belt followed by finder grits.
Any other suggestions?
Re: Somewhat OT - cleaning a deck
Ed Wozniak-Buffalo, NY
Are you trying to paint or stain the deck? You implied that it was already painted. If you want to repaint it seems like anything that was not removed by power washing would be stable enough to paint over.
Sky's the limit!
Jason Roehl in Lafayette, IN
What do you want to spend?
How much work do you want to put into it?
For the absolute best chance of longevity in the new finish, you would need to get down to bare wood. To do that, you would use a chemical stripper. There are several on the market, and the ones that seem to work the best are made (primarily) of NaOH (sodium hydroxide). Note that these are made for stripping decks--other paint strippers would work also, but these are made from decks, and are going to be less toxic when they are rinsed off (NaOH is a strong base that is easily diluted by water). Definitely protect your eyes and skin when using--I have a scar where some got on a relatively fresh cut and ate a 1/4" diameter by 1/4" deep hole in my finger.
After stripping, rinsing and drying, sanding is not a bad option, especially if the wood is heavily weathered and splintering--don't go too fine here, 80-100 grit is plenty smooth, and will still allow for good absorption of the finish.
I wouldn't recommend paint. The failure mode of paint (and it will fail), is chipping, cracking and peeling, which is ugly. Get a good waterborne solid-color stain rated for decks (many are not rated as scuff-resistant, and are not appropriate for a walking surface). When solid-color stains fail, they wear away in small particles and can simply be cleaned and recoated several times before complete removal is necessary.
Clear coats and semi-transparent stains have even shorter service lives, but are generally easier to renew as well. Cheap clear finishes may not even last a year, the best might get you 2 years, semi-transparent stains may get you 2-3 years. Solid color stains will typically last 3-5 years. One of the biggest mistakes people make is not keeping their decks clear of organic debris, especially leaves--wet leaves leach tannins onto the deck, and help keep the surface wet, which will accelerate the breakdown of any finish.
Jason
