Joining Short Moulding Into Long
John McGaw
I am in the final throes of finishing up my library/gallery room (the carpet installers are downstairs right now stretching) so there is just a fireplace mantle and some moulding to fit. One feature I want is to have continuous picture rail moulding (profile shown) to eliminate the need to punch holes in the walls to hang things. Problem is that to get the stuff sent in at reasonable cost it will need to be in <8-foot lengths and some vendors go even shorter. Does it seem reasonable to pre-join the shorter pieces? I was thinking of the usual scarf joint but with some thin plywood strips maybe 6" long and 3/4" wide let into routed rebates in the back of the mouldings so that I could pre-join and pre-glue the pieces before hanging them near the ceiling. My thought that doing it this way should allow a less obvious join with no need to make them at the studs (24" OC). The profile shown is for the simplest moulding available which is 3/4" thick by 1-3/4" high. Since the room design is very understated this seems to be sufficient to me.
