Re: Tung Oil
Keeping in mind the comments to Alan Young's counter-slab . . .
Waterlox is one of the few finishes actually made with tung oil. Big advantage of Waterlox over a linseed oil finish is that, although both will "amber" the surface, the tung doesn't darken over time. Where Waterlox comes up short is in the Wear Department; it is not a very hard or abrasion-resistant film. I do, however, use it when finishing darker woods (walnut and cherry). I have used the original Sealer, the High Gloss (more resins), and the Marine Sealer which is great for outdoor wood furniture. On interior items I will often use one application of Sealer, then a coat of Gloss, then a tie coat of dewaxed shellac, and lastly a cross-linked top coating of a waterborne such as General Enduro Clear or HP Poly.
I always use gloss clears rather than semi or satin because the flatting agents muddy up the refraction and visual depth of the top coat. I prefer to rub out the final coating to the amount of gloss or satin I want on the piece.
hth
