Refinishing a Lane Cedar Chest
Pic 1
Tthe first picture shows the chest as it was. It was my mother's hope chest.
PIC 2
Picture 2 reveals the date it was made. The serial number is read backward, in this case 01/05/40.
The wood was coated with shellac. Could it be that already in 1940 that nitrocellulose was being diverted to explosives and not lacquer? I stripped with solvent and then sanded lightly to make it all uniform.
PIC 3
Picture 3 shows it ready for staining. Note the wood has aged a yellow brown. The purples of new walnut are long gone from sun exposure. The sanding dust was yellow-brown.
Picture 4 shows it stained. The stain is Japan Color Burnt Umber 12% in General Finishes stain base.
The gaudy veneer is not my "cup of tea", but it was my mother's and it will be kept. Note the color change in the center book match as the sun grazes the front. Straight on the color is essentially the same.
Re: Refinishing a Lane Cedar Chest
Clint Searl
I assume the stripper was DNA?
stripping details
Up until my last two stripping projects I had only ever stripped cross linked finishes-varnish, polyurethane and the like. In these cases the finish never dissolves. Rather it swells and gets rubbery when exposed to solvent. I apply a thin coat of a methylene chloride stripper, wait a bit and then the rubbery finish can then be easily scraped off in sheets with a putty knife. I follow up with a clean up with steel wool.
However, both lacquer and shellac dissolve in the stripper resulting in a viscous "glue". When I used the technique described above it failed. A film of "glue" was left behind that stuck to paper towels and steel wool and resisted efforts to remove it. I realized that when I left a concentrated solution of lacquer or shellac on the surface as a surface film it would be like leaving behind a film of Duco cement.
What worked was to apply a thick layer of stripper. Instead of leaving it to set on the finish I worked it with a brush. Working it dissolved and then diluted the finish into the stripper solvent(methylene chloride). The thick goo that resulted was then scrapped off and the process repeated. After the second treatment the wet film that remained was too dilute to act as Duco cement. I could then clean up with steel wool.
Re: Refinishing a Lane Cedar Chest *LINK*
David Yoho
Nice job on the Lane chest. I've restored a number of Lane chests over the years. I recall the oldest was from 1935 and one of the shortest in width I've seen.
In case you weren't aware, Lane has had a program for years where they will replace the old lock for free. Most of the original locks were found unsafe because children could accidentally get locked inside. I've changed about three over since they offered it. Follow the link below or use the toll free number for information and ordering.
(800) 327-6944
Lane Lock Replacement
