totes
james runchey
Am I the only one on here who has no idea what a tote is?
totes
james runchey
Re: totes
Curt Stivison
A tote is something you tote things around in
Hand plane rear "handle" is called a tote
you too can talk like a hand planer
tote- the thing you hold whilst planing
iron- what most anyone else would call a blade
frog- the thingy that supports the blade
sole-bottom of plane, that which must be flattened to be accepted as hand planer
mouth- what the blade sticks through(maybe the blade should be called a tongue)
cap iron- AKA, chip breaker except that isn't something it does. It holds blade to frog except in special cases it is the shaving bender to prevent tear-out.
tear-out- AKA #!$&(!!@#$!! what happens when novices plane
screw- screw, used to hold plane together. Also exclamation novices use after tear-out and before reaching for ROS.
Re: you too can talk like a hand planer
craigd
(verse)
Lever cap, screw cap connected to the cap iron
cap iron connected to the frog
frog connected to the sole
(chorus)
Dem bones, dem bones, dem dry bones
Now hear the sound of wood being sliced
Re: totes
Sgian Dubh
As Curt says, a tote is something you use to carry things around in, a bit like a bag I suppose. But tote seems to be the new trendy name for what I learnt from old cabinetmakers as the handle at the back of a plane. Knob at the front, handle at the back. I really don't know why someone came up with the name tote for the handle. Next they'll want to call the handle of a saw or a chisel a tote. Where might it end? Slainte.
Re: totes
james runchey
I must of had a brain freeze.....when you were talking about a rosewood tote, my mind didn't connect with a plane. I'm not quite over the hill, but getting close!
You forgot...
Mark Nowicki
... arris, sometimes known as an edge, and that ubiquitous "fettle"
Also one should be prepared to debate, at lenght, the difference between 0.000008" and 0.0000078".
Mark
Re: Picture of tote.. *LINK*
Mark Nowicki
...sometimes known as "carry on luggage"
Brother, where ar't thou . . .
Steve Mackay
Hey Dude ! I was where you are 'bout ten years ago. My next question was "What's a frog ?" !
Then, while doing the Google, I stumbled over Wood Central. The college professor who THOUGHT he knew about "sub-cultures" never ran across anything like this !
