Gate Leg Card Table Finished
Stephen Kirk
A few weeks ago I finished my first gate leg card table. Both back legs hinge out. I used a wooden hinge as I found regular leaf hinges too wobbly. The base is red oak, top is white oak with some ambrosia maple for the center sections.
I decided try the 3 side border so when it's open it has a full edge. I also wanted to let the center section float, so this uses a Greene & Greene style breadboard end. Looking back, I would have been better off with stable wood and no edging. This was more work than it was worth. I used Soss Invisible hinges - they looked tough but were actually rather easy to install. I used a doweling jig to drill them out and a bit of chisel work to clean up the edges.
Opened up it looks a bit spider-ish.
In use it's quite nice. I used a synthetic leather for the top. It is glued down with flour paste. 2 months in it seems to be holding just fine. The paste is quite reversible if there is ever a problem. There is no padding, which you might normally find on a modern poker table. I made add some on a next table, it makes the cards a bit easier to handle.
This was a fun and useful project. I plan to work out more types of transforming furniture. It's a joy to build and use. I'm still in awe of some of the period pieces of transforming furniture with gears, springs, pulleys, etc.
