Have some cabinets to build
Richard McComas
The face frame and raised panel door are to be made of either African mahogany or Sapele.
What's the difference between the two. Is one or the other easier to work with? More stable ect? I'll be doing my own stock prep.
Re: Have some cabinets to build
Sapele (IMO) can be a bit of a pain to work. It is quite hard. I've turned it mostly. It dulled the tools quickly. The grain can be quite interlocked, so I'd take care when routing it (if you rout it). Straight cutting should be no problem. If you are doing rails and stiles for doors, I'd be careful.
African mahogany (Khaya) - I found easier to work. IMO it is somewhat softer and easier to turn and machine.
Both are really pretty woods - but I think sapele is prettier.
John in NM
I've never worked with Sapele. I believe it is harder and darker than African Mahogany.
I have worked a bit with African Mahogany, you can get a wide color variation between boards, so staining can be a requirement. I've never had any stability problems with it, though density can vary a lot it all seems to be pretty stable. Interlocked grain makes for a gorgeous ribbon figure, but can give you tearout problems when planing. Nice sharp blades should help some.
Also, watch out for cross grain cracks. There were a bunch in some 6/4 I bought for interior doors, ended up with much more waste than expect having to avoid those. I've not seen them in the 4/4 we're buying recently, so maybe it was a fluke. All I can figure is wind damage maybe?
Keith Newton
I would go with Sapele if it were me. I think the end results will be better. It has a higher level of chatoyancy, and if there is a certain place that would benefit from having extraordinary grain, there are some wonderful veneers always available in Sapele.
I have found there to be lots of reaction wood in the African Mahogany that I have used. Watch for, avoid the bands of more orange, duller color, maybe ragged torn fiber from the saw tooth on your rough lumber. You can find good looking wide boards that when cut into styles and rails, they will twist and bow into unusable worthless trash.
Agree with Keith
I've found sapele to be more user-friendly and less reactive than khaya, the predominant species that is lumped under the term "African mahogany." There actually are no true mahoganies in Africa, so African mahogany is more of a marketing term than anything else.
Sapele is a lot more interesting looking than African mahogany, in my opinion -- more uniform in its dark reddish brown color and much more likely to exhibit exotic figure, such as blister, quilt and especially ribbon stripe. I have found that sapele -- even the most highly figured wood -- planes absolutely beautifully with sharp hand planes. It is also more stable dimensionally.
