I need to make a baffle for a heater out of sheet aluminum. I was thinking of cutting up some cookie sheets for the aluminum parts, but am not sure of the best way to cut. Too heavy for shears. Any advice for cutting the parts with either my band saw or table saw? Or other suggestions?
band saw works if you have a fine tooth. 6 tpi might work but finer would be better. 4 tpi is scary (now how do you suppose I know that?) . Saber saw works well too and you can get fine toothed saber saw teeth. You can use a table saw if you can find a very fine toothed blade. I have a 7" blade steel blade that I use. It makes a LOT of noise. But, be wary of the aluminum sticking to the teeth. I have had that happen on thicker stock. Not good. Band saw is safer.
For straight cuts, I like the TS, with a sled, with low hook triple chip blade, and scrap of MDF under to make zero clearance on both sides of the blade.
I'd use a shear (but I happen to have a small beverly). Lacking that a good cold chisel (with a bit of practice it works nearly as well as a shear). An angle grinder will work but the cutting disk will likely be ruined. I don't like cutting aluminum with woodworking tools though it can be done.
I've got a Kett sheep's foot shear and use the dickens out of it.
The same mechanism mounts on your drill too.
either way you'd be ahead of the game if you had some extra jaw screws. They're socket head cap screws and not easy to scrounge or source at the time they break...Sunday evening
Oh, William,,,,,,,,,,,,,,,,,, Say it ain't so! You didn't really, did you? ha
Tell me that you watched someone else do that. Otherwise, I'm afraid I'm going to have to ask you to lean in real close to your computer so I / we can deliver your dope-slap. Although I can imagine that if someone slides a piece of aluminum up to the blade, the slamming of the brake is probably a pretty instantaneous slap.
It was a much more subtle mistake than you are imagining. My wife had some bound documentation that she needed to unbind to run through a copy machine. It appeared to be all paper, cloth and glue, but inside the cloth binding was a very thin layer of metalized mylar. I cut several of the bindings off with no problem, cutting through the top and bottom invisible layers of aluminum with no problem. But then I moved the fence a smidgen, and the blade ran through the about 1/2" vertical layer of the back of the binding, and BAM! I immediately knew what had happened, as I've sacrificed several hot dogs to Mr. Gass's mechanism in demonstrations, but it took some careful examinations to figure out why it happened. No headslap is necessary when you trigger that brake. "The air was shattered by the force of Casey's blow."
The brake and the Freud Fusion blade make a great shop clock.
