A discussion of drawer construction wood
A significant mentor to my woodworking, Buddy Floyd, learned the trade as an apprentice and furthered his experience in furniture repair and conservation. Buddy advocated that drawer runners should be built from a hard wood, maple for example, and the drawer side should be of a softer wood. The reason- drawer sides are easy to repair when worn while the runners and dividers are not.
Last week I was cleaning up my childhood desk for my granddaughter. While the desk was bought in 1956, it was only regularly used for about 15 years. Later in life it was used lightly or not at all. The drawer sides are beech and the runners are soft maple. Even after this amount of use the runners show grooving from the hard beech drawer side sliding on the softer runner.
I have seen English furniture, typically made with oak drawer sides and mahogany dividers, where the drawer had cut 1/4" into the divider over the course of 150 years of use. Repairing this wear compared to adding 1/4" to a worn drawer side would be more difficult.
Re: A discussion of drawer construction wood
Mark
This may be cheating, but since I found the nylon 1 " one sided sticky tape, no drawer runner or guide is safe.
It allows the drawers to run smoothly regardless of the season and helps reduce the wear on the runners.
Still agree harder wood for runners makes sense.
I have believed this for so long I thought it was something "everybody" knew.
Can't remember learning it, but I thought there was also discussion of the coefficient of friction being less if one were had and the other soft.
This information (?) may have come form a furniture restorer about 40 years ago. He had a show room and then I was astounded that he also had a huge warehouse with probably five hundred pieces in it.
Where do you get the tape?
Does this work well and stay in place? How much does it cost and where did you get it?
Re: Where do you get the tape?
Merle
Barry, I thought "everybody" knew about this stuff. :D There are a number of brands, colors, thicknesses, widths, etc. Here is a sampler:
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=uhmw&rh=i%3Aaps%2Ck%3Auhmw
What I have used has stayed in place. It is great where ever you want a slippery surface.
don stephan
Always thought one of the advantages of drawer slips was the increased width of bearing surface on the drawer runner, to reduce the rate of wear.
Mark
Lee valley was my source.
I found the one inch wide was all I needed, you could cut it easily to get smaller widths if needed.
Not expensive and a as most drawers are 16-18 " , one roll goes a. Long way
Stuart Johnson
By fixing the drawer side do you mean adding a wear strip to the bottom of the drawer rather than trying to replace the side?
How worn drawer sides are repaired.
A typical Period style drawer has a bottom that can be slid out from the back. It would be unusual to find an antique piece made otherwise. After the bottom is slid out the drawer is fixed in a vise and the worn edge is hand planed straight and flat. A suitable "sliver" of replacement wood is glued on. Finally, the piece added on is planed to restore the drawer to its original size. If the drawer was originally made to accommodate this repair it is possibly the easiest repair that can be made to a piece of furniture.
Re: How worn drawer sides are repaired.
Gary Smyth
When it comes to wood drawer runners, I was taught to install them a bit proud of the frame rail. That way when the drawer sides form a groove in the runner it does not also groove the show front of the frame. The amount is small and it doesn't work with flush drawers (unless the drawer sides are amended) but it does work with over lap or lipped drawers to prevent the frame from requiring correction and refinishing down the road. If commmercial nylon strips are used on the runners their typical thickness is plenty to accomplish the same goal.
Merle, As soon as I know something, I assume everybody else knows it too. Somehow it does not occur to me that I could possibly know anything that everybody else doesn't know.
Merle
Barry, you know more than most and certainly more than I do. I was teasing you about your previous post in which you used everybody in quotes.
